FS/FT:2000 gsr engine low miles legit with title ! plus optional accesories - $1500
i have up for grabs a 2000 gsr engine. it is for the most part a full swap minus the transmission and shift linkage that i sold already. it has a JDM type r valve cover, fairly new NGK plugs and wires, blox intake manifold, ACT streetlite flywheel with an ACT sprung 6 puck with what looks to be a stock pressure plate.(idk it came with it when i bought the car) comes with ECU, it is wired up dor a msd blaster coil with the 6al ignition that is also available for a little extra, otherwise you need your own distributor. engine harness, (in excellent condition) i will include an injen short ram with filter. i also have billet avid mounts if you want/need them for an extra 150$ for a 94-up integra/92-95 civic so it can be a drop in swap for your EG or DC. and i also have a hytech replica big tube header that i paid 575$ for brand new and was on the car for maybe 4,000 miles and is in great shape...i will let it go for an additional 400$
The list...
Motor only with harness, ecu and intake- $1500
avid mounts - $150
hytech big tube tri Y header - $400
msd 6al setup w blaster coil and distributor - $200
****if you want everything your price is $2000 or as i said reasonable trades for k swap parts****
Call and ask for Andrew anytime 845-659-5138
The list...
avid mounts - $150
B20-GSR
May 7, 2010 04:52 PM
myhatchrips
Oct 20, 2004 01:10 PM
PhantomTegTypeS
Oct 18, 2001 05:12 AM
