Old Apr 6, 2015, 09:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Power Steering Noise and foaming fluid
Old Feb 6, 2010 | 01:36 PM
questseek's Avatar
Default Power Steering Noise and foaming fluid
I have a Honda Accord v-6 , when it's cold the powersteering pump makes noise .
The steering in the car is fine , but I notice when it's cold on start up the the pump makes noise , when car is standing still and I turn the wheel from left to right it also makes noise and sometimes the power steering fluid in reserve foams up.. Sometimes when driving it still makes a noise and sometimes the noise goes away.. Please help!
Old Feb 6, 2010 | 02:59 PM
The Jar's Avatar
Default Re: Power Steering Noise and foaming fluid
Check the fluid level. Check for leaks in the PS fluid line. My PS cooler was corroded and leaking fluid and that was the cause of the noise. No other ideas.
Old Feb 6, 2010 | 10:17 PM
nicolaselias's Avatar
Loved
Community Favorite
I had a simialr problem and it was one of the bearings (and accompanying seals) in the power steering pump itself
Old Feb 6, 2010 | 11:46 PM
nus_dogg's Avatar
Yeah, gotta make sure your pwr steering fluid level is full at its mark.
Old Feb 7, 2010 | 06:57 AM
uccjxe's Avatar
There are instructions somewhere posted on replacing the shaft seal on PS pumps; they suck in air (esp in cold when fluid is thicker) and cause foaming. Also check the two clamps on the suction hose from the reservior to the pump.
Old Feb 7, 2010 | 07:25 AM
TheMuffinMan's Avatar
He knows where you live!
Bingo, I'd wager you have an air leak somewhere in the line, look around the PS components and see if you see any leaks.
Old Feb 8, 2010 | 08:05 AM
shortlid's Avatar
Icon2 Re: Power Steering Noise and foaming fluid
My P/S pump on my '99 EX 4 cyl. sedan is weeping out the pump body. Bought seals to rebuild pump but instructions would be SWEET!! Anyoen know where there posted??
Old Feb 10, 2010 | 09:11 PM
H23-Vtec's Avatar
New User
if u r xperiencing squeaking noise while turnin or wn idle then change d steering belt it shud solve ur prob. bou d pump no idea
Old Mar 6, 2010 | 07:37 PM
skavfive's Avatar
New User
Post Re: Power Steering Noise and foaming fluid--warning read the service bulletin
I had this same problem--there is a service bulletin for a worn rubber o-ring in the inlet line for 03-08 V6 Accords that lets air into the system making the noise--especially when cold. The Honda dealer didn't even know it and first flushed and changed the reservoir and then tried to sell me a new pump.
Only after I showed him the bulletin did they hand me the o-ring and I fixed it myself in twenty minutes. I replaced the o-ring and the noise went away immediately.
The dealership was embarrassed and refunded my money for the flush, but I wonder how many $600 power steering pump replacements they did instead of replacing the 25 cent o-ring.
-Skavfive:
Old Mar 6, 2010 | 08:49 PM
HonBeer's Avatar
?? Is that some sort of english? We dont need that on this forum. We should not have to work to try and that jibberish your typing!
Old Mar 6, 2010 | 09:32 PM
slomofo's Avatar
GDD Member
Default Re: Power Steering Noise and foaming fluid--warning read the service bulletin
-Skavfive:
This man speaks the truth.
It appears that his writing is more legible than yours. Please pack up your useless posts and show yourself the door now.
PS - You can take your improper punctuation with you.
CheezeFrog
Nov 18, 2019 11:11 PM
sky9
Feb 25, 2011 02:40 PM
Inextricabledrvr
Mar 18, 2009 07:56 PM
'00Accordster
Sep 25, 2004 08:52 AM
Elvis1977
Dec 16, 2003 07:46 PM
