Timing. please help me Clarify!
Old Feb 6, 2010 | 12:21 PM
:::SIRll_EJ1:::'s Avatar
Default Timing. please help me Clarify!
so i have a ej which ive swapped a dohc engine into, the engine turns over and kicks la ittle bit like it wants to start but doesnt seem to have enough mechanical energy..electrical is fine..
ive tried re-doing my timing 3 times and engine gets CLOSE to startinfg up.
If my Intake cam is off by one whole tooth and the whte line on my crank pulley isnt completely lined up with arrow on my block, would that cause my engine to not fire up???
Old Feb 6, 2010 | 12:55 PM
TheAsian's Avatar
Default Re: Timing. please help me Clarify!
You are speaking w/ you trying to set it to TDC right. The engine should start with timing set like that but it would have major lack of power. It sound as if it were missing. I strongly suggest before going any further to fix your timing and get everything aligned properly before going any further.
I would prolly replace the belt and tensioner at least.
After that check batter voltage tranny ground make sure you do have the problem amount of juice to get it started. How is your spark. Good strong spark or kinda weak.
peetie87
Dec 8, 2010 11:47 AM
Rostr02
Aug 11, 2005 06:19 PM
BB6racer
Jun 16, 2005 12:04 PM
1987CRXSi
Dec 29, 2004 07:12 AM
inetj
Oct 19, 2004 05:31 AM
