Suspension & Brakes Theory, alignment, spring rates....
pics of your low del sol or eg civic
Old Feb 5, 2010 | 05:45 PM
4ghatch's Avatar
Default pics of your low del sol or eg civic
i have a 93 del sol and hve it droped with neuspeed race springs 2.0" reear and 1.75" front on 15" rims 205/50/15 i woul like th go lower and would like to get a look at your setups for an idea of whats what. thanks
Old Feb 6, 2010 | 07:50 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: pics of your low del sol or eg civic
https://honda-tech.com/forums/showthread.php?t=1865873
click that then refer to the one below.
https://honda-tech.com/forums/suspension-brakes-54/you-cannot-ride-slammed-have-smooth-ride-2603553/
Old Feb 6, 2010 | 05:28 PM
4ghatch's Avatar
iv'e seen this post
1 there are like no del sol's in it
and 2 they dont say what they have done or any specs at all! this what i need
Old Feb 6, 2010 | 07:47 PM
Egezzy's Avatar
1 there is a slammed setup thread in this forum.
2 no matter the chassis it is the same. get adjustable suspension and drop it. get it aligned. call it a day.
a. do what was mentioned in 2.
b. run like 13x8 with a 185/45.
c. lay frame like jenna jameson.
Old Feb 7, 2010 | 10:35 PM
4ghatch's Avatar
wow "no matter the chasis" huh?.... so a 2" drop looks the same on a crv, ridgeline and crx
sounds like you dont know **** stop wasting my time
Old Feb 8, 2010 | 06:08 AM
Egezzy's Avatar
yeah you are right. i have no idea what im talking about but then again im not the one asking the question. maybe you should look through this forum more and notice the slammed setup thread.
Old Feb 8, 2010 | 11:43 AM
DR.DelSol's Avatar
you have a del sol if im correct?
well get some koni yellow shocks and get ground control coilovers and set them both on the lowest setting and there you go, your F***ing slammed
Old Feb 8, 2010 | 08:23 PM
4ghatch's Avatar
ok on one is getting the point of this post i am trying to see pics of del sol lowered with the specs of parts used so know how low they are and the rim size ect..... for a visual btw fu*k sleaved coilovers unless they are built in they are trash
Old Feb 8, 2010 | 08:52 PM
DR.DelSol's Avatar
then heres a slammed sol
Old Feb 9, 2010 | 08:05 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
GC sleeves on Koni Sport shocks are NOT trash. There are TONS of full "built in" adjustable coilover suspension setups out there that are MUCH lower quality than GC/Koni. Research before you start spewing useless garbage in here.
There is already heaps and bounds of info on this stuff in these forums. Hell the OP of the slammed thread has a del Slow.
BrianDelSol
May 23, 2006 05:51 AM
Han Solo
10
Jul 19, 2005 10:42 AM
SofaKing
Dec 31, 2003 03:30 PM
YellowCivic95
27
May 8, 2002 05:49 PM
