Analyze my dyno results
Old Sep 5, 2002 | 07:10 PM
satan_srv's Avatar
Default Analyze my dyno results
Okay here are my dyno results...these are SAE numbers. I changed the cap/plugs/rotor/wires/valve adjustment so it would finally dyno properly
These two runs were done consequtively...i.e. Dyno...slow down...dyno.
Okay looks like a pretty standard Prelude Dyno....now when I put the Air Fuel On, I get a little suspicious...
Is it really that bad?? Is that hella rich? And look at the difference in a back to back dyno? What the hell is going on? There's even more fuel on the second run!
Thoughts/Comments?
Old Sep 5, 2002 | 07:20 PM
Accord94DX's Avatar
Default Re: Analyze my dyno results (satan_srv)
looks fine.
my a/f was at 11.9 on nitrous before leaning it out a lil.
RAB's Avatar
RAB
What year prelude to you have, I'm guessing its not a 5th gen as the RPM range is high than that.
Old Sep 5, 2002 | 07:44 PM
satan_srv's Avatar
Default Re: Analyze my dyno results (RY8127)
Read sig
Old Sep 5, 2002 | 08:10 PM
PreludeRacer023's Avatar
what does the year have to do with anything??? it would still be an H22, the 5th gens dont rev higher than the 4ths..same motor.
Old Sep 5, 2002 | 08:14 PM
satan_srv's Avatar
I just realized the Dynojet graph numbers for A/F are of for some reason...here are the A/F numbers at various rpms...
3500 - 13.82
4000 - 14.07
4500 - 13.79
5000 - 13.67
5500 - 13.64
6000 - 13.44
6500 - 12.92
7000 - 12.15
7500 - 11.32
7800 - 10.96
Old Sep 5, 2002 | 08:16 PM
satan_srv's Avatar
Default Re: Analyze my dyno results (PreludeRacer023)
H22A1's peak at about 6800 rpms...
H22a4's peak at 7400rpms
They aren't the same motor
Old Sep 5, 2002 | 08:26 PM
Cottonwoodz's Avatar
I would say its alittle rich(12.15 @7000 RPMs) I would lean it out.. 14.7 is the correct Air/fuel ratio, but I myself would not sit their. 14.2-13.7across the board would-be something to shoot for.. Get a VAFC and tune it, you will feel a differance.
IMHO
Old Sep 5, 2002 | 08:30 PM
Mike95lude's Avatar
No no, that's way off. 5th gen's peak at 7,000 exactly.
Your graph says two things. One, its very rich in the late rpm's. Two, kinda proves shifting at around the real redline is optimal, not fuel cut.
Old Sep 5, 2002 | 08:50 PM
satan_srv's Avatar
Default Re: Analyze my dyno results (Mike95lude)
7000...yeah but according to my 5thgen friends dynos they were peaking at 7200-7400 just with bolt-ons
Hmm so can I choose V-AFC settings based on this? Apparently my tq numbers are good
[Modified by satan_srv, 12:52 AM 9/6/2002]
Old Sep 5, 2002 | 09:19 PM
Mike95lude's Avatar
yeah your torque #'s are pretty good. I've seen a lot of 5th gens with mods that can't even hit 140 wtq. I know stock 5th gens peak at 7000. With bolt-on's I guess it could shift upwards.
Old Sep 5, 2002 | 09:22 PM
Mike95lude's Avatar
I'm also thinking that maybe the stock ignition can't produce enough spark to properly burn all the fuel at such high rpm, hence the flooding of fuel in the air/fuel ratio...?
Old Sep 5, 2002 | 09:25 PM
satan_srv's Avatar
Well I justchanged all of my ignition except the coil....but i thought something like an MSD ignition would do nothing for an N/A engine
I think I'll try again in a week with 92 octane instead of 94, I used to have problems with 94...
[Modified by satan_srv, 1:26 AM 9/6/2002]
Old Sep 6, 2002 | 01:55 AM
H23 Power's Avatar
get an afc or more bolt ons and get the top end to lean out more
you want the a/f line flat
Old Sep 6, 2002 | 02:18 AM
kjohnl's Avatar
Default Re: Analyze my dyno results (F23 Power)
Nice
Old Sep 6, 2002 | 04:57 AM
fastludeh22's Avatar
Default Re: Analyze my dyno results (kjohnl)
one thing i was thinking is, you see that big jump where vtec engages, i think you could make more power by having it engage a little sooner, may also help smooth out the curve some also.
one way ive heard of doing iot is, dyno w/vtec engeaing at like 7000 rpms, and againg at 2000 rpms, where they cross would be a good point to start at for vtec engagement. then just fine tune the fuel and the exact point. do some more tuning and lets us see the next one...
damn i cant wait to get my car back!
Old Sep 6, 2002 | 05:43 AM
satan_srv's Avatar
Default Re: Analyze my dyno results (93ludevtec)
yeah like running both the cams separately...but there's not that much area to gain...the vtec cam drops pretty quick on the graph...I'm engaging at 5000 there..maybe lowering it to 4900 would help...
Old Sep 6, 2002 | 07:13 AM
LudeBehavior's Avatar
New User
I thought if you engaged it later like 5700k or 6k would solve a lil of the dip before vtec engages...or what else...I think I heard of maybe an integra ecu would fix alot of the dip problem but would lean it out more frequently.
Old Sep 6, 2002 | 07:45 AM
satan_srv's Avatar
Default Re: Analyze my dyno results (LudeBehavior)
Actually I really don't see any dip on the graph...VTEC crossover looks good to me...
Old Sep 6, 2002 | 08:45 AM
you should lower your engagement to 4700, thats where mine is...also what rpm a car makes its max power is dependant on alot of things, mine makes its max power well above 7 grand i can assure you that, i cant wait to get my car to a dyno...peace
Old Sep 6, 2002 | 06:39 PM
H23 Power's Avatar
lol
what you want to see is nothing...a good graph is when you cannot tell where the vtec crossover is...your's you can obviously tell, just like any other stock H22
4700 is usually the best point to smooth it out...
making it higher will just make it worse
right now your just missing power from 4700-5000, there's a potential for about 20-25 hp to the wheels right there
Old Sep 19, 2002 | 12:38 PM
metal-x's Avatar
Is there always a dip in the powerband past 7k on all h22's?
Old Sep 19, 2002 | 01:31 PM
aklucsarits's Avatar
New User
Default Re: Analyze my dyno results (metal-x)
Looks perfectly normal to me. After 7000 rpm, it gets a little rich, but that's by design just for safety's sake to accomodate a wide range of environmantal conditions. You could stand to lean it a tad in the upper rpm range and gain a HP or two. But don't go too crazy.
Andrew
Old Sep 19, 2002 | 02:15 PM
satan_srv's Avatar
Default Re: Analyze my dyno results (aklucsarits)
Thanks for the input, I'll have a new dyno up in a few weeks...looking for big gains
Old Sep 19, 2002 | 03:45 PM
Tomakit's Avatar
If you could lean it out up top the tq wouldn't drop off so bad I'd imagine. That'd also keep your hp climbing in the upper revs.
Tom
