what is piston to deck ???
Head Gasket thickness, etc.
Here's a decent guestimator
www.zealautowerks.com
It's always better to measure it. If you don't have the tool, you can use a dial indicator. Once you get it TDC, rock the piston fore and take measurements at the intake and exhaust side of the piston. Rock the piston aft, and do the same thing. Then average those numbers out. Then you can decide if you need to deck it to get the compression you are looking for with what gasket thickness is available and make sure you have proper piston to head clearance. You really need to measure it rather than ask someone, or rely on a "calculator".
93H22ACX
Jun 15, 2004 02:39 AM
