Gettin the rex BAR'd Monday. Few last questions
Old Feb 5, 2010 | 10:51 AM
4LugR's Avatar
Default Gettin the rex BAR'd Monday. Few last questions
Before I go to bar, two questions. Does anyone know if I will still pass if the battery is relocated to the trunk? Because the gsr airbox won't fit with the battery in it's normal place. Lol. And does it matter if my harness uses obd 2 injectors and an obd2 distributor? The rest of the harness is obd 1. TIA for the help guys
Old Feb 5, 2010 | 10:57 AM
4LugR's Avatar
Default Re: Gettin the rex BAR'd Monday. Few last questions
Oh ya one more question to all you b swapped rex's. Is there any way to make the engine more solid when it's mounted? I've got the hasport mounts and there's only 3 on there. The front one won't go on bc I put a hydro tranny on it. Is there any more bracing I can do to stiffen it up?
Old Feb 5, 2010 | 11:15 AM
.Manny.'s Avatar
Touching My Member
I believe you are fine with the obd2 stuff. Not exactly sure on the battery, I really doubt it will be an issue since it's not emissions related.
The hasport mounts aren't stiff enough? I have 4 or 5 yr old innovative mounts and they are more than enough on their own.
Old Feb 5, 2010 | 11:39 AM
crx_si-r's Avatar
From the sounds of everything you should be fine
Old Feb 5, 2010 | 12:34 PM
4LugR's Avatar
Ok cool guys thx. I've got a dc header and skunk 2 mani. But ther both carb legal so they shud be fine too.
Old Feb 5, 2010 | 12:41 PM
crx_si-r's Avatar
Yea as long as it has carb numbers.
Old Feb 5, 2010 | 01:42 PM
scottmog's Avatar
your battery shouldnt matter.
yup exactly
A_Rotary_Guy
Feb 3, 2008 03:50 PM
sbcrx
11
Dec 23, 2004 11:20 PM
PDXHatchback
Jun 24, 2004 08:50 PM
