Whats my ECU?
Old Feb 5, 2010 | 02:08 AM
lostinmiself's Avatar
Default Whats my ECU?
I just got done pulling a B20 with a b16 tranny from a true RHD eg6. now i believe the ecu was the stock one but there are no markings on it. nothing besides a date stamp. is there a way to tell what sort of ecu it is? i mean the eg6 comes with a b16, you wouldn't run a b20 off that ecu so im assuming it has to be changer right? im going to keep looking and reading up on it. But any help would be great
Old Feb 5, 2010 | 11:27 AM
dpetro1's Avatar
Default Re: Whats my ECU?
can you open the ecu and look for any markings/labels. there might be something on the inside near the ecu plugs. other than that, take some pics and post them up
Old Feb 5, 2010 | 12:00 PM
gettin the screwdriver and the camera
Old Feb 5, 2010 | 12:40 PM
The ecu says
IPT
A8Y-E
M66207
5112353G2
and im working on getting decent pictures
Old Feb 5, 2010 | 03:18 PM
Relic1's Avatar
if there are no markings or no lables on the ECU, it's highly unlikely that it's factory. Someone spent the time to remove the lables...
read the three digit code on the largest square chip inside the case of the ECU.
the picture will tell us the rest of the story.
Old Feb 6, 2010 | 02:36 PM
301
>>> i cant get any pictures to show up with enough quality to make it worth your time looking at.
Old Feb 6, 2010 | 08:18 PM
Relic1's Avatar
the fact that I knew what it was off the top of my head means I need to get out more.
301 = P06 originally.
most likely since there are no labels it's been converted to run VTEC and chipped to run what ever it was meant to run.
So what's in the ECU isn't going to tell you much, what's in the chip is everything.
Find a local tuner or shop that tunes and have them read the chip.
Or better yet have them make a basemap for your setup.
Old Feb 6, 2010 | 10:32 PM
well i am planing to use the same ecu to run the swap that it came with. the only problem is i just wanted to know what it was. now ill have a local tuner look at it if i can get a hold of him and then go from there. thanks for the info relic1
-Justin-
Honda CR-V & Element
Sep 18, 2018 01:15 PM
sins
Mar 31, 2008 12:23 PM
SOHC_MShue
Oct 14, 2002 11:22 AM
