Transmission & Drivetrain Gearboxes, Differentials, Clutches
NEED TO KNOW IF MY TRANSMISSION IS OUT! NEED HELP ASAP
Old Feb 4, 2010 | 08:38 PM
JDM_Si_EG6_FTW's Avatar
Default NEED TO KNOW IF MY TRANSMISSION IS OUT! NEED HELP ASAP
Okay, so i need some opinions on what could be the problem. I have a cable LS transmission on my B16a first gen.
Symptoms:
I have to shove it into first gear.
Every gear grinds (most of the time)
Very hard to shift into gear while driving. with the exception of 5th
EXTREMELY Hard to get into first gear while stopped or slowing down.
When downshifitng to slow down all gears grind. With the exception of 5th
And when all this started it likes to kinda jump if you will.. like lets say if i have my clutch pressed in.. but its still in gear. if i rev the engine just a bit the car seems to pull or jump.
What could be the problem or problems?
Please help guys.
Old Feb 5, 2010 | 05:19 PM
JDM_Certified's Avatar
Default Re: NEED TO KNOW IF MY TRANSMISSION IS OUT! NEED HELP ASAP
possibly low or no mtf....
Old Feb 9, 2010 | 05:13 PM
andrewd_89's Avatar
either your clutch pedal needs adjusted because its not fully disengaging the clutch or your diaphram springs in your clutch disc broke....your transmission is fine, your clutch is the culprit.
Old Feb 10, 2010 | 08:50 AM
Nealoc187's Avatar
From: West suburbs of Chicago, IL formerly Kalamazoo, MI
exactly that andrewd 89 said.
Old Mar 29, 2010 | 12:50 PM
ben_briand's Avatar
i have this exact same problem with my 93 integra. some times it works kinda ok but most of the time it bucks coming to a stop so i have to put it in neutral then stop and then shift it to 1st, every gear grinds unless i shift at very low rpm and it still takes awhile to fall in gear. i adj. the cable but it didint help, its full on tranny fluid and the clutch does not slip every.
Old Mar 30, 2010 | 03:02 AM
Mista Bone's Avatar
D Tranny Guru
typical B series clutch that has spit out a spring.
Old Apr 7, 2010 | 12:15 PM
ben_briand's Avatar
so if i buy a clutch kit and change it, this will most likey fix it??? or coild it be a transmission problem?
VtecAdvantage
Jul 23, 2006 02:43 PM
craiger
Nov 19, 2005 06:15 AM
elips0id
Apr 1, 2004 03:38 PM
[626]95-GSR
Aug 11, 2002 12:24 AM
Jmm0056
Sep 12, 2001 01:54 PM
