Need some advice !!! asap !!
Old Feb 4, 2010 | 05:11 PM
aDrEnAlInE_FrEaK's Avatar
Default Need some advice !!! asap !!
Hey guys i have a few questions for the honda masters!! I have a b16 that pretty built and it went to the dyno and got tuned and im pretty disapointed in what heppend !! SO the car went to vip performace in portland, car was tuned on chrome and converted on E85 due to the fact that i didnt want any detination on pump gas.. car put down 178hp and 147tq !! ryan at vip seems to think that im over cammed and its killing me in power due to the fact that when v-tech engages at 6k the power drops down and takes all the way to 9300rpm to hit the 178hp mark.. He said that he played with the cam gears and timing for six hours to get the cams somewhat dialed in and the fuel mixture and all that tuning stuff with the computer is perfect so i dont know what else it couldbe.. so i need some opinions because personally i dont think the car is over cammed.. All info will be considerd and i want to solve this problem asap.. list of mods to engine
B16a2
skunk 2 pro series intake manifold
blox 72mm throttle body
whale dick intake
rc 400cc injectors
walbro 190 pump
bennen industried fuel rale with pressure regulator
buddy club spec 4 cams
buddy club cam gears
buddy club dual valve springs
blox titanuim retainers and keepers
ferrea stainless valves
blox extreme race header
ported and polished head by my boys at aluminum cynlinder head rebuilders
5 angle valve hob
12.5 to one je pistons and had the head decked and block decked
eage h-beams
balanced and bluprinted crank and polished
arp main studs and head studs
i might be missing some stuff but i just need some opinions guys, i know 178hp is decent on a b16 build but i no it should hit the 200 mark.. Thanks guys !!!
Old Feb 4, 2010 | 05:20 PM
Natural Aspirations's Avatar
Default Re: Need some advice !!! asap !!
178 isnt horrible
what you have is an over built b16 (KISS)
Throttle body and header are probably a little oversized for your needs and may be hurting you
bc4 cams are not too big for your setup, same vtec lobes as skunk 2 tuner series stage 2
Old Feb 5, 2010 | 05:19 PM
Originally Posted by Natural Aspirations
178 isnt horrible
i just wanted to build something different and was expecting higher numbers but maybe i was just expectig too much.. Thanks for the quick responce and info
any other opinons ???
yoassisdead
Feb 4, 2017 09:09 AM
killakalipoph
Engine Management and Tuning
Jun 21, 2009 03:57 PM
firstclassjdm
Aug 27, 2007 12:02 PM
