Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Srs light - bad seat sensor?
Old Feb 4, 2010 | 03:08 PM
mhmmofr0's Avatar
Default Srs light - bad seat sensor?
My wife's 02 ex ww/ 83k had the srs light come on this week. This is a car w/out side air bags. A coworker of mine scanned it for us. It came back with a error w/ the drivers side seat sensor. The shoddy haynes manual does not have a wiring diagram of this circuit.
How should i go about diagnosing this? Does any one have the ohm spec that the sensor should have?
Also how can i tell which airbag controller we have?
thanks
Mark
Old Feb 5, 2010 | 03:58 AM
97twodoor's Avatar
Default Re: Srs light - bad seat sensor?
Very common froblem on these civics. The seat belt switch often fails and sets a code. The fix is to replace the seat belt buckle attaches to the seat. A word of caution for you though, if you don't know what you are hooking your ohm meter up to when servicing the SRS be prepared to deploy air bags and seat belt buckle charges. You could be seriously injured.
Old Feb 5, 2010 | 10:25 AM
mhmmofr0's Avatar
Thanks for the info however i don't see how ohm testing a sensor could set off the air bag. Any way does any one have the spec for this?
Also where is the airbag controller?
Old Feb 5, 2010 | 10:28 AM
It Wasn't Me's Avatar
If you don't think it's broken, reset the SRS light.
If it comes back on, throwing the same code, replace your seat belt buckle. (as noted)
Old Feb 5, 2010 | 12:05 PM
mhmmofr0's Avatar
How would that tell me its the sensor and not the cpu or the wiring?
Old Feb 5, 2010 | 02:24 PM
Well, let's go back a little. Which DTC (code) are you getting?
This thread may be of some help. https://honda-tech.com/forums/honda-civic-2001-2005-78/srs-light-2671768/
Old Feb 7, 2010 | 06:24 AM
chawski's Avatar
Ive said this a few times before, ill say it again...
When i brought my 01 in for the airbag recall, the tech noticed my srs light was on, and took care of it, free of charge. It might be worth taking it by a dealership and see what they say.
Old Feb 8, 2010 | 02:08 PM
Und3rCrown's Avatar
New User
this should help you out if you didn't fix it yet, just bookmark it so next time you can set it up https://honda-tech.com/forums/showthread.php?t=2128335
Old Feb 9, 2010 | 03:55 AM
97twodoor's Avatar
When you check resistance of anything with an ohm meter it sends out low voltage and current through one lead then measures the amount coming back at the second lead. It takes the information and calculates that circuits resistance. It might be just me but i would'nt risk putting current through an inflator module especially when they can be deployed with only a little static electricity.
Angeles1262
Acura TL, RL & ZDX
Apr 24, 2017 11:09 AM
AWSMDOG
Apr 15, 2017 12:33 PM
FlewByU352
Jul 13, 2009 04:45 PM
BobWilson
Jul 24, 2007 06:07 PM
