hb w/gsr starting issues
Old Feb 3, 2010 | 08:51 PM
gota00si's Avatar
Default hb w/gsr starting issues
i have a 90 base model hatch. i am having a problem with it not starting. somtime i will go out to start it and when i turn the key not all the light in the dash will light up. if this happens you can hear the relay click but not puls the fuel pump. if i try to start it the car will not turn over. if you turn the key off the cel and bat light will stay on. if you hit the brakes the cluster will light and the relay will kick. give it a little while and try it again, turn the key on and everything work like it should. if you hit the brakes, turn signals, and headlights they all work. none of the light, signals and the brake lights work when it will not turn over. it has actually shorted out while running and it just runs till fuel pressure is to low then it dies and wont start.
i have checked the following.
igniton switch
main relay
boom slange harness
engine harness
computer
radio wiring
wiring in the doors speakers
the mods of the car
99 gsr full swap
obd1 dizzy
obd1 injectors
obd1 p72
golden eagle intake manifold
boom slang harness
full si interior plastic
rear disc swap
hasport mounts and shift linkage.
any ideas on whats making the car act the way it is? i thought maybe a short somewhere so i started to change the relay and the ignition switch. i have looked over some of the visable wiring and changed what i thought was bad. thanks for any info on finding out whats wrong with my car is greatly appreciated.
Old Feb 4, 2010 | 06:22 PM
gota00si's Avatar
Default Re: hb w/gsr starting issues
if anyone has any ideas you can pm me or post here. but pls someone help me out.
Old Feb 18, 2010 | 08:10 PM
gota00si's Avatar
still having the issue. anyone have any ideas. thanks.
ElMaq
14
Mar 19, 2024 03:54 PM
cleanM1
May 3, 2012 10:31 AM
bryan24207
Jan 19, 2012 07:53 PM
SaveDaNoob
Jul 7, 2011 07:06 PM
Chief Brody
Aug 30, 2005 08:58 AM
