WA- Full LS-vtec swap.. b18c/golden eagle/sk2/aem... LOOK
Old Feb 3, 2010 | 07:56 PM
dougday84's Avatar
Default WA- Full LS-vtec swap.. b18c/golden eagle/sk2/aem... LOOK
I'm looking to sell my damn near complete LSvtec swap.. IT's a b18a with b18c head.. looking for 1500 local or 1650 shipped.. Here's what I got.. no part outs!!! The block is completely together, but I have not bolted down the head to the block nor bolted the cams down in the head.. So if you are local, you may inspect everything before buying...
THIS HEAD HAS NEVER BEEN TORQUED DOWN TO THIS BLOCK!!
HEAD..
B18C HEAD
COMPLETE AND ALL OEM PARTS
PAINTED YELLOW VALVE COVER (ORIGINAL WAS KINDA CRAPPY.. BUT LOOKS GOOD NOW)
OEM GSR HEAD BOLTS, ONLY TORQUED 1 TIME.
ALREADY BEEN TAPPED AND PLUGGED FROM THE VTEC CONVERSION KIT
HAS ALL SENSORS
HAS VTEC SOLENOID
HAS 10 MM SPARK PLUGS WIRES
HAS ALL GASKETS
HAS NGK SPARK PLUGS
STOCK GSR INTAKE MANIFOLD
METAL VTEC TUBE REDUCER THINGS FOR VTEC SWAP (BRAIN DEAD, CANT REMERMBER WHAT YOU CALL THEM..??)
*70MM SK2 THROTTLE BODY (VIN PLATE STILL ON, GOOD SHAPE, HUGE!)
*EXTRA AEM TRU TIME ADJUSTABLE CAM GEARS (BLUE)
*AFTERMARKET HEADER AND DP.. NOT SURE BRAND, BUT GOOD SHAPE.
BLOCK
B18A1 BLOCK
ACL ROD BEARINGS
ARP ROD BOLTS
OEM LS RODS
B16A PISTONS W/NEW OEM RINGS AND WRIST PINS
BRAND NEW HEAD GASKET
GSR OIL PUMP
BLOX OIL ADAPTER SANDWICH PLATE.. (FEEDS HEAD WITH OIL FOR VTEC CONVERSION, SUPER CLEAN)
BRAIDED STEEL LINE FOR OIL SUPPLY
ALTERNATOR
POWER STEERING PUMP
AC PUMP
ALL BELTS/HOSES.
ABSOLUTELY COMPLETE
B SERIES STARTER
TRANSMISSION
S1 CABLE TRANNY (TYPICAL 3RD GEAR HIGH RPM GRIND)
CLUTCH CABLE
EXCEDY OEM CLUTCH KIT
AASCO MOTORSPORTS LIGHTENED FLYWHEEL
MANUAL (THERE IS A DIFFERENCE) CV AXLES.. BOTH LEFT AND RIGHT AND HALF SHAFT
AUTOMATIC CV AXLES, BOTH LEFT AND RIGHT AND HALFSHAFT
SHIFT LINKAGE
SHORT SHIFTER
(ALL TRANNY PARTS ARE OFF OF A 91 INTEGRA THAT HAD A GSR SWAP)
NOW FOR WHAT IS MISSING..
ECU..
DISTRIBUTOR.. (I HAVE AN OBD1 LS DISTRIBUTOR THAT WILL WORK, BUT MUST BE MODIFIED)
GSR FUEL RAIL..
AND THAT'S IT!!!! This is a very complete kit. I was swapping my auto db1 with this setup, but bills have forced me to sell all this stuff.. my loss, your gain, don't miss out. I paid 900 for the head and golden eagle vtec kit alone.. And I have ALOT of parts here.
Shipping will be provided but from gate to gate only.. if you would like to a personal location, then you will have to pay the difference.. my price is 1500 pickup or I can drop off locally (bremerton is where I'm from) or 1650 shipped.. I will lose a bit if i ship but goes with the game.. All shipping will be insured, and this stuff will be shipped neatly in a crate.
Payment.. .would prefer paypal, but can discuss different payment arrangment with the proper buying.
Here are some pics guys!
also, notice I have not installed this motor, ever.. everything is just sitting on the block, and I have all the nuts and bolts for the install. I also have a coffee can FULL of misc. honda nuts and bolts to go with the swap.. I kid you not, this is super complete.
Here is my number, I have more forsale ads on here, still have a B17 Block that is in good shape, 100 buck!!
360 649 2694
thanks for looking
-Doug
Old Feb 3, 2010 | 10:32 PM
dougday84's Avatar
Default Re: WA- Full LS-vtec swap.. b18c/golden eagle/sk2/aem... LOOK
ttt.. bumpity bump bump.. also have DA motormounts..
Old Feb 4, 2010 | 08:12 PM
dougday84's Avatar
up up up.. make an offer if I'm too high..
dc4ok
Jun 9, 2011 03:26 PM
mamaboy
Sep 26, 2004 05:37 PM
b18bturbo
Mar 31, 2003 11:28 AM
g2turbo
Mar 3, 2003 07:23 AM
