Raising Compression for better Throttle Response?
Old Feb 3, 2010 | 04:17 PM
GEN2 LS's Avatar
Loved
Default Raising Compression for better Throttle Response?
setup is a 81x89 ls/v
pr3 pistons
itr cams
etc etc!
I plan on doing alot of auto-x and hpde events this year instead of drag. I got a chance to drive my friends ls/v the other night and I was surprised at how much faster it felt than my car, when he is only making about 5-8 more whp than my car. After giving me some details on his setup it's the same setup as my car as far as bore and stroke, but he is running ctr pistons and pro2's and skunk2 flat face valves. Estimated compression is around 13:1 he said. Anyway the point i'm trying to get at is his cars throttle response was damn near instant and while my car does pull, his power just seems more on tap and it's just there when you lay into it. I would like to raise my compression as well for sheer throttle response, I don't care about power output as this motor isn't intended for straight line purposes. Could I run ITR cams with that much compression, or would I need bigger cams? If so what are smallest cams I could get away with using?
Old Feb 3, 2010 | 04:29 PM
Natural Aspirations's Avatar
Default Re: Raising Compression for better Throttle Response?
Cliff notes:
Pro 2 Cams
Vs.
ITR Cams
Hmmm......
Old Feb 3, 2010 | 05:01 PM
GEN2 LS's Avatar
Loved
Originally Posted by Natural Aspirations
Cliff notes:
Pro 2 Cams
Vs.
ITR Cams
Hmmm......
I should re-word my post hahaha! his car feels faster under the curve, like before you hit VTEC etc. if you understand what i'm trying to say. I mean I know it should be and feel faster than my car anyway.
Old Feb 3, 2010 | 05:03 PM
00Red_SiR's Avatar
All Motor Mentor
That's because the Pro 2's have much larger than stock primary lobes which is what you operate on before VTEC, making a lot more power "under the curve" and before VTEC.
Old Feb 3, 2010 | 05:06 PM
GEN2 LS's Avatar
Loved
ok thanks for that info, would more compression cause that as well? Could I even run pro2's with just pr3 pistons?
Old Feb 3, 2010 | 05:19 PM
00Red_SiR's Avatar
All Motor Mentor
More compression on ITR cams would give a very slight lift in power but nothing equal to the power gain of installing pro 2's. Pro 2's will work in many builds and work best in the ones with good supporting mods. You could always try them and find out for yourself. If you don't like them, you can always sell them easily as people are always looking for some.
Old Feb 3, 2010 | 05:25 PM
You have plenty of compression as you are.
etc etc
chrisff521
Jul 20, 2009 08:44 PM
boy_hapon
Dec 19, 2005 02:39 PM
itr1244
May 12, 2005 10:30 AM
dizzyroc88
Nov 17, 2004 03:39 AM
TypeR15
Jul 18, 2004 11:35 PM
