Civic to Integra transmission mount change up?
Wasn't able to find the answer searching....
I have a 2000 model civic EM1 with oem B16A. The transmission engine mount has too much freeplay and needs to be replaced. I know the design is different from that of say a 94-01 Integra B series mount, can they be interchanged??
Thanks!
here's a 2000 Civic Si oem mount pictures #2, and the bracket number 6
here's one for a 2000 model Integra, part #6
Thanks!
Are you asking swapping the # 2 for the equivalent in the eg/dc2 chassi ?
You cant, they mount differently to the chassi
your best bet is order aftermarket mounts.
Heres a better representation of what I wanted to say.
Check the chassi of the integra, The rubber piece mounts to a part that is welded to the chassi. ( if you cut it out of an integra and weld it in yours, then yes you can use the integra transmission mount. )
CRXB5
May 23, 2011 03:00 PM
2000, 2005, 94, acura, changing, civic, equivalent, honda, integra, interchange, mount, rl, si, trans, transmission
