Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Gauge Cluster Wire Color Codes
Old Feb 3, 2010 | 08:16 AM
rediye's Avatar
Default Gauge Cluster Wire Color Codes
Hi Guys
I am looking for a diagram that show what color wires are used for for a 2002 civic ex auto for a gauge cluster. something like this:
http://img.photobucket.com/albums/v4...-00diagram.gif
Ive been searching all night an cannot find anything.
if this helps i need to know the wire colors for:
ground- black
trunk light or hatch-???
right turn signal-green/yellow
left trun signal-green red
brake light-???
seatbelt light-red/blue??????
low fuel-blue/orange
fuel gauge-yellow black
speedo-blue/white
tach-blue
temp-??????
power-yellow(green harness)
charging light-???
oil pressure-yellow/red
power-red/black (blue harness)
check engine-green/orange
high beam-red/blue (red blue is already in use for seatbelt)????
dimmer-?????
gauge lights
power- white/red (green harness)
I am doing this cluster swap into an ek. the rpms work, the speedo seems sluggish like its not reading properly, the water temp doesnt work. the fuel works but my empty sits at 1/2 tank on the cluster. the high beam, trunk, dimmer dont work. and the brake light will not go off. any ideas??????
thanks
Old Feb 3, 2010 | 12:43 PM
Spoon ES2's Avatar
Default Re: Gauge Cluster Wire Color Codes
4dr or 2dr i need to know ill get u the diagram
Old Feb 3, 2010 | 12:48 PM
Spoon ES2's Avatar
Old Feb 3, 2010 | 12:49 PM
Spoon ES2's Avatar
thats all i got for u hope it helps
rediye's Avatar
ya its a 2dr. thank you sir
Old Feb 3, 2010 | 12:51 PM
Spoon ES2's Avatar
np man doing what i can to help a fellow 7thgen
Old Feb 3, 2010 | 12:52 PM
rediye's Avatar
do you know what the temp wire is?
Old Feb 3, 2010 | 12:53 PM
Spoon ES2's Avatar
what u mean by temp wire i dont understand ure question
Old Feb 3, 2010 | 12:55 PM
rediye's Avatar
what color is the temp wire? example: blue/green
i have the rpms and speedo working. the fuel works but the 1/2 mark is where my gauge reads zero
the only thing i really need working right now is the temp gauge
Old Feb 3, 2010 | 12:59 PM
Spoon ES2's Avatar
u might have the change the way they read i dont think both car for the same wire setup let me see what wire is temp gauge if i can find it
Old Feb 3, 2010 | 01:02 PM
rediye's Avatar
ok cool man here is a link to the ek cluster. i need to match up pretty much all of them to the es2 cluster.
i really dont care about the srs abs or cruise. i dont have that in my car im just worried about the ust haves in the cluster.
thanks again! this is a huge help.
Old Feb 3, 2010 | 01:03 PM
Spoon ES2's Avatar
the cluster dont have wires by itself the car mixed wit the multiplex system
Spoon ES2's Avatar
np man i can try to see but its a white green wire that come from the ecu if u wanna run a extra wire for it
Old Feb 3, 2010 | 01:05 PM
rediye's Avatar
ya i thought it was the white green wire but i hooked it up and nothing happened.
should i try tapping it to the ecu? i have a p30 ecu
Old Feb 3, 2010 | 01:42 PM
Spoon ES2's Avatar
idk let me check ill get bak to u
Old Feb 4, 2010 | 05:46 PM
rediye's Avatar
hey guys
heres a little update. everything works on the cluster except the damn water temp. the fuels 1/2 mark is my empty lol but i can deal with that.
the ebrake light stays on but thats nothing big either.
can anyway shed some light on the water temp???? i have the correct wire- white green to yellow green. nothing is working.
all the gauges do tiny jumps for about 5 sec when i first turn the car on so i know the water temp is working but not reading.... any thoughts?
Old Feb 5, 2010 | 10:01 AM
rediye's Avatar
bump
Old Oct 6, 2023 | 03:10 PM
Doucette18's Avatar
Does anyone know what the white and green communication wire is?
afterdark
10
Feb 25, 2012 09:31 AM
bakoCRX
Jul 16, 2009 07:25 AM
vtecn8ive
27
Nov 4, 2007 05:41 AM
quis84
Feb 7, 2006 10:14 AM
Gumbey75
Mar 25, 2005 08:20 PM
