tb swap, coolant temp code?
Old Feb 3, 2010 | 06:34 AM
www.megameet.org's Avatar
Default tb swap, coolant temp code?
So I have a jdm b20 swap in my crv (awd manual) and I swapped out the TB to a b16a2 one, to go bigger and to get rid of the fitv. Now I'm getting a coolant temp sensor code all of a sudden. When I start the car, the car idles down real low, and doesnt come to normal temp (900) until its warmed up. Before it's warm it's at like 4-500 but idleing. No bouncy idle.
From day 1 owning the car the iac hasnt seemed to work. Put in a brand new one, and nothing. Unplug it, nothing happens, and no code. Try to turn the ac on at idle and it cuts out, becasue there isnt enough idle once it drops to sustain it from day one.
When the new tb went in, there was no outlet for the hose to the charcoal canister, so i rmoved it. I did this on my old civic without an issue, but now when I throw the coolant code, this one has started to come up as well. Shouls I put it back in and use the outlet on the rear right of the IM that seems to never be used?
Any help would be awsome. I am working on trying to get a new iac now, or at least swap one out to see if there is a change.
Old Feb 5, 2010 | 11:13 AM
Default Re: tb swap, coolant temp code?
bump
Fantastic420
Oct 7, 2009 12:16 PM
SnIpErS-GsR
Feb 25, 2007 07:09 PM
forcedaccord95
Dec 18, 2004 09:24 PM
cliff666
Jan 4, 2004 10:50 PM
