FS: Built 1999 GSR *NEW PRICE*
SOLD
Engine Specifications:
B18C1 Bottom end, balanced/machined by Engine Design in Delavan, WI:
81.5 CP 11:1 Forged pistons(Assembly CC'd at King to exactly11:1)
New 87mm OEM crank
Crower Billet forged rods
Cometic Head gasket
ACL bearings
ARP studs top and bottom
Moroso Steel 5q pan, 304SS stud kit
STR BG
Hasport 70 durometer mounts
New water pump, oil pump, belt, timing covers and OEM hardware
Head:
B18C1
Complete Stage 3 package from King Motorsports
Skunk 2 PRO 2 cams
Crower PRO micrometer style cam gears
Super tech valves and springs
Crower Steel retainers
OEM seals, tapered bronze guides
Shaved Mugen VC with 2x-12an catch setup
Edelbrock Victor X matched (drilled and tapped for DP dry system)
Edelbrock 65mm TB
Custom tuned 23.25" intake with Blox V-stack
Hondata gasket
Trans:
B16
Type R LSD
4.785 OEM JDM final drive
LS 5th gear
Fidanza Flywheel
Competition Clutch #1620
SS line to New OEM master
Heat treated and painted case
Type R shifter, OEM linkage, 90D bushings
New OEM hardware as seen in picture
Fuel System:
5g Fuel cell
Aeromotive EFI pump
Aeromotive A1000 FPR
RC 550cc(currently 40% duty)
-6an feed and return push lock with nickel plated fittings
-6an Earls Pro-lite with Ano tuff black fittings elsewhere
Edelbrock PRO EFI rail
Ignition/ECU:
OEM dist.
MSD wires
MSD extrernal coil
P28 ECU
S300 Hondata
Header/Exhaust: Custom
JG PRO FLOW modified with 3" collector , into borla XR-1 race muffler, DT dump under car.
Cooling:
Be Cool Pro Stock dual 1" core, crossflow 22"x13"
CSI catch
single 10" fan
170* thermostat/Mugen fan switch
(185* cruising temperatures)
Brakes:
Power stop
Hawk pads
SS lines
Willwood P-valve
New hand bent hybrid lines
Line lock ready in the rear
Suspension/Wheels:
Omni Power coilovers 10k/12k
Skunk 2 A-arms
Omni rear LCA and camber links
ASR rear brace
No roll bars
Coated suspension
90D bushings
Custom front traction bar with QA1 ends
ARP front hardaware included
Centerline forged polished aluminum 15" x 7" fronts with MT drag radials
Centerline forged polished aluminum 17" x 7" rear with Kuhmos
Misc specifications:
Chassis weight: 2205 with a full fuel cell, balance is 63% over the front
Car made: 210/140 on motor (built for 150-200 2 stage spray)
Interior: see pictures
Trunk fabrication: see pictures
Front end fabrication: see pictures
Too much more to list.
Added Oct.7th
New 87mm OEM crank
Cometic Head gasket
ACL bearings
STR BG
Head:
B18C1
Skunk 2 PRO 2 cams
Edelbrock 65mm TB
Hondata gasket
Trans:
B16
Type R LSD
LS 5th gear
Fidanza Flywheel
Fuel System:
5g Fuel cell
Aeromotive EFI pump
Ignition/ECU:
OEM dist.
MSD wires
MSD extrernal coil
P28 ECU
S300 Hondata
Cooling:
CSI catch
single 10" fan
Brakes:
Power stop
Hawk pads
SS lines
Willwood P-valve
Suspension/Wheels:
Skunk 2 A-arms
ASR rear brace
No roll bars
Coated suspension
90D bushings
Added Oct.7th
Thanks everyone.
However pretty happy with the numbers considering the car was built for spray. The intake, collector, cams, mild compression 11:1, and 93 pump gas...car made good power for some of those oversized parts and lower compression IMO.
ASR sells the rear brace with or without the sway bar, the car doesn't have any sway bars, it doesn't need them. the brace was enough to tie the back half together and keep it on the same plane and axis after removal of the metal and re-fabrication in the trunk.
TTT
TTT
havent talked to you in a while
