Do I need a second fuse or a bigger fuse?
Old Sep 5, 2002 | 04:14 PM
4doorH22's Avatar
Default Do I need a second fuse or a bigger fuse?
I've got a single battery in the trunk mounted in a box. There is a 60 AMP fuse on the box. All of the car's power needs go through this fuse, including a 50x4 into 4 ohm PPI amp. I'm going to be adding a 400x1 into 2 ohm PPI, I intend to hammer this system, and was wondering if I can still tap the power line after this fuse? Or should I set up another fuse box on the battery box just for the amps? Or do I just need a bigger fuse on the existing fuse holder? Or am I fine the way it is? Maybe just try running everything off the 60 AMP and see if it blows? I wouldn't want that to happen on the highway. I will also be running smaller fuses on the power distribution block before the amps as well.
Thanks
[Modified by 4doorH22, 8:15 PM 9/5/2002]
Old Sep 6, 2002 | 07:34 PM
DB5000's Avatar
Default Re: Do I need a second fuse or a bigger fuse? (4doorH22)
Satforn
Acura TL, RL & ZDX
Nov 21, 2018 03:27 PM
monsterCHILD
Jan 6, 2011 04:28 PM
mandybliss
Jul 31, 2009 06:02 AM
Bucktown
Audio / Security / Video
Mar 8, 2004 06:11 PM
Nameless RB26
Jan 8, 2003 05:35 PM
