F.S. Complete Turbo Setup, MSD setup, STR manifold, Volks w/drag radials
Complete B-Series turbo setup. Made 340whp/270wtq + some on a bone stock LS motor. XS Engineering TO4X turbo, Custom 2.5" charge pipes, HKS Type R BOV w/filter, Tial 35mm wastegate, 3" custom downpipe, Maxrev stainless mani, Stainless dumptube, Greddy type 24 Large FMIC, -10 Stainless braided return line with earl's fittings, -4 stainless feed line with oil feed tee for back of block, Turbo XS manual boost controller, GM 3bar map sensor with pigtail, Golden Eagle Vacuum Block, and ALL couplers, vacuum lines, t-bolt clamps, and everything needed. All you would need is a fuel setup, tapped pan, and modifying the upper charge pipe depending on your intake mani. $2450 obo
Tein Type Flex with JDM ITR rear lca's. Coilovers and LCA's were both bought brand new and have approximately 2000 miles on them. SOLD!!!!!!!
MSD 6al with Blaster Coil and custom mounting tray and OBD1 LS distributor and coil wire. $425
STR Intake Mani for LS motors with Hondata heat shield gasket and OE throttle body. $350
Volk GRN's. 15x7 +35mm. ONLY A PAIR! with BFG 225/50/15 Drag Radial. $550
Sorry, I'm keeping the kit complete. If it doesn't sell, then I'll use it. Thanks though.
