i need help with my injectors
Old Feb 2, 2010 | 06:57 PM
nebraskaimport's Avatar
Default i need help with my injectors
ok im running a 95 integra stock motor just a aftermarket clutch i have a a/r-.50 turbo with full 2.5" exhaust i just picked up a set of 450cc injectors the guy told me i need to hook up resistor's to them so does anyone know what size of resistor's i need and how to hook them up????
Old Feb 2, 2010 | 09:05 PM
jdm602's Avatar
Default Re: i need help with my injectors
if you cant find a resistor box, buy some 10watt 10ohm inline resistors at a parts/electronics store like radioshack and solder them inline on the black/yellow wires.
Old Feb 3, 2010 | 10:16 AM
timmy tegra's Avatar
Pick up a dsm resistor box or go to a junkyard, im pretty sure older modle accords have them.
Old Feb 3, 2010 | 10:19 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
there are tons of them at the junk yard, just any old honda pretty much, find a pic of one online first so you know what to look for.
Old Feb 6, 2010 | 11:30 AM
ok do i cut the wire first then solder them in like that?
Old Feb 6, 2010 | 01:24 PM
jdm602's Avatar
for the inline resistors...yes.
Old Feb 6, 2010 | 02:44 PM
iamthefollower's Avatar
it's much easier wiring in a resistor box from an EF or a DA I actually did this about a week ago, didn't take long at all.
Old Feb 9, 2010 | 05:53 PM
ok i would but i live in a small a$$ town in bfe lol slim pickins around here
Old Feb 9, 2010 | 05:55 PM
and how would i wire in the resister box if i found one? idk how to do that i only build motors and transmissions
Old Feb 9, 2010 | 06:31 PM
bigD's Avatar
try the faq at the top of the page, everything you need is in there
Old Feb 9, 2010 | 08:01 PM
Loved
Community Favorite
if you need one I have three available. Ill sell it to you for $15 shipped.
Old Feb 9, 2010 | 08:03 PM
TwinCityTuner's Avatar
inline resistors is super easy. you just cut the wire and solder one in for each resister. takes ten minutes. electrical tape over the resistor and you are good to go. should go on the yellow and black wire
Old Feb 10, 2010 | 06:03 PM
thanks for all the help ill just do the resisters. i have one more thing to ask of you all. what are some good plugs to run i do know .28 on the gap but i've tried the ngk irra. but they just burnt up right away so if you guys have any advise it would help
Old Feb 10, 2010 | 06:08 PM
lyncoors's Avatar
tune? what was your afr
Old Feb 13, 2010 | 01:41 PM
im tuned by chrome on 8lbs 440cc and a 255 fuel pump one guy told me it was my map sensor since im running stock map sensor but when they tuned my car they said it would be ok since im only running 8lbs. i know i need to change my pistons and rings brfore i can push any more boost and i really do want to
BrothaSit
Jan 9, 2006 09:20 PM
tranceologist
Aug 21, 2005 07:57 PM
ekblacknight
Jun 20, 2005 01:35 PM
2k1_ITR_0736
Jul 1, 2003 02:45 AM
