Suspension & Brakes Theory, alignment, spring rates....
D2s or Ksports ???
Old Feb 2, 2010 | 05:31 PM
rico892002's Avatar
Default D2s or Ksports ???
i recently got my tax money back and i wanted to know some review on both sets of these coilovers. i dont have the money for gc/ky so people please dont say get koni yellows and gc. i will be getting the d2s or the ksports in the next few days so i just want to kno which will be better
Old Feb 2, 2010 | 06:50 PM
dandaman15's Avatar
Community Builder
Default Re: D2s or Ksports ???
What type of car are they going on? You can get gc/koni for $800 and Ksport and D2 are right around there. If you absolutely have to chose between those two I would pick ksport but there are better options. Look up PIC, Progress, and even Buddy Club depending on what you want to do.
Old Feb 2, 2010 | 08:05 PM
.Manny.'s Avatar
Touching My Member
They are the same piece of **** suspension. Get Progress, PIC, or Koni/GC. Get quality parts, not anodized garbage.
Old Feb 2, 2010 | 08:19 PM
rico892002's Avatar
its going on a ek coupe, i really dont think they are ****. my buddy have progress coilovers on his dc2 and that **** rides like ebays
Old Feb 2, 2010 | 11:25 PM
STOCK_SOHC_DX's Avatar
Those are obviously the best 2 choices you can get for that amount of $$. Honestly though if you want to roll the dice I would go with Ksports supposedly they revamped their designed. Koni/GC > those 2, if you already didn't know.
I really doubt these rides like Ebays since I owned their old set on my DC2 and that rode pretty damn good. With the new design it should be better than that old set I had.
Old Feb 3, 2010 | 02:26 AM
Prophecy101's Avatar
i have a set off progress coilovers on my wifes car. n for some reason im not satisfied wit the way they ride either
Old Feb 3, 2010 | 05:44 AM
.Manny.'s Avatar
Touching My Member
So what's the reason behind you choosing purple/orange > quality/lifetime warranty
Old Feb 3, 2010 | 09:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Every time this topic comes up I like to throw out the fact that my Koni Sport shocks are 8 years old with over 180K miles on them, and still going strong. Yes the shocks cost around $500 alone for the set, but where else are you going to get that kind of life out of dampers - those things that auto maintenance groups will tell you to replace every 50K?
Old Feb 3, 2010 | 11:13 AM
.Manny.'s Avatar
Touching My Member
Can't beat that with a bat
Old Feb 3, 2010 | 12:16 PM
Hawkze_2.3's Avatar
The better question is what makes you think that they are different aside from the color?
Old Feb 3, 2010 | 12:27 PM
702Prodigy's Avatar
PIC/Progress have a lifetime warranty? If the car will only be for daily driving nothing wrong with D2/Ksport/FF or any of the purple/orange coilovers. Yes, GC/Koni is a great alternative cause with the Koni you get a the lifetime warranty. Koni with any sleeved styled coilover would work. To me its all about the shock. Have a good shock, you can put whatever spring company on and the ride will be good.
This is my first time with a Honda/Acura (only owned VWs), I currently have D2 coils on my Integra. No problems yet and had the set for 3 years. Would a GC/Koni setup ride better? Defenitely. The dampening on the D2s ain't to good. But, the car only takes me to work and back. Gave me the drop I wanted and got them for a good price.
My VWs had:
H&R ultra lows coilovers (this was the best riding coil I've owned. Lifetime warranty)
Bilstein sports with H&R race springs (Very firm, but the car felt very sure footed)
Koni sports with H&R race spings (Rode really nice, preffered the feel of Bilstein instead)
Old Feb 3, 2010 | 12:37 PM
Community Builder
Maybe, but not as well as GC's which are designed specifically to work with and properly capture the circlip on the Koni shock body, with no other O-rings or spacers required. With this setup the Koni OE-style spring perch is not used at all. It effectively turns the Koni damper into a threaded-body damper.
With cheap sleeves you still have to use the Koni spring perches and use o-rings or spacers between the sleeve and the shock body, and cheap sleeves would still be prone to mushroom out at the bottom and crack under the car's weight, corrode, etc.
Koni/GC really is a super-slick setup and IMHO one of the best for the money.
Old Feb 3, 2010 | 01:05 PM
702Prodigy's Avatar
So basically only the sleeves are needed. I know GC is made by Eibach so quality is top notch for the springs, but what I'm getting at is the shock is more important. Who knows where those other sleeved coilover springs are made, they may fail eventually.
Would ebay coilover springs w/ GC sleeves on Koni shocks be as good as the GC/Koni setup? probably.
Old Feb 3, 2010 | 01:31 PM
Originally Posted by crucian
I have had my Ksport coilovers in less than a year now and one already blew. Car was not slamming either. Luckily I didnt sell my Koni yellows and H&R sport springs yet. I just switched them back in now the tires are rubbing in the back. The konis are still holding up after 5+ years. I know there are others out there with the Ksport problem, has anyone been given a hard time with the shock being replaced by Ksport?
Ksport owner here. Source:https://honda-tech.com/forums/showth...port+coilovers
Originally Posted by 90blackcrx
Contact me, I should be able to get them this week if you want them. I'm a PIC distributor. As for D2, we use to carry them until our mass distributor stopped carrying them because all the returns he was seeing.
Here is a retailer and this is what he said about D2's. Source: https://honda-tech.com/forums/showth...port+coilovers
What Pat is trying to tell you that GC makes their sleeves to fit the Koni shock perfectly and is warrantied for life to not fail when paired with Koni shocks. Koni will also tell you that you need adapters to run any type of sleeves not made by Ground Control to keep their warranty. Also Eibach does not make GC or vice versa.
Old Feb 3, 2010 | 02:17 PM
.Manny.'s Avatar
Touching My Member
When I posted the lifetime warranty, I meant Koni. Sorry about that, I should have been more clear
Old Feb 3, 2010 | 02:39 PM
dandaman15's Avatar
Community Builder
No, ebay springs are crap and it would be more expensive to go that route in the end anyway.
Old Feb 3, 2010 | 03:33 PM
rico892002's Avatar
thanks guyz for the info. i would really love to have a set of koni/gc i just really think its to expensive for what im getting out my car, i cant really see myself spending over a grand for somthing im not going to be autocross all the time. its just my dd with some weekend dragstrip days. and i just wanted something pretty stiff. if i did get koni/gc i would get the race struts with 10k in f and 12k in r with tophats and a nice swaybar in the rear. but that set up will be on somthing when i can afford it
Old Feb 3, 2010 | 03:55 PM
dandaman15's Avatar
Community Builder
Like I said before its only $800 for the gc/koni set-up without top hats. You can use your stock ones just fine though.
Old Feb 3, 2010 | 04:59 PM
702Prodigy's Avatar
I thought Eibach made the GC springs? I thought all these coilovers were all made in Taiwan, but with specs made specifically for each manufacturer?
Like I said, the D2 coilovers on my Integra has given me no problems for 3 years now. Maybe i'm lucky. If and when they go bad, I'm switching to non-adjustable damping coilover with lifetime warranty. I prefer a coilover thats specifically damped for the springs used instead of a bunch of adjustments. I say I adjusted my D2 like a total of maybe 5 times since getting them. LOL.
Old Feb 3, 2010 | 05:47 PM
dandaman15's Avatar
Community Builder
Ground Control just uses Eibach springs for thier sleeves. They dont make them specifically for Ground Control its just their regular coilover spring. It also says you live in Vegas, which why it might not be that big of a problem. You dont see drastic temp changes and see salt and snow on the roads. Because of that the roads are also so much better. Living in Wisconsin with some of the worst roads in the nation, and just yesterday getting about 2 in of snow and salt they wont last long at all. Coilovers should just be tested here because if they could stand up to DD use here they would last everywhere.
Old Feb 3, 2010 | 06:33 PM
.Manny.'s Avatar
Touching My Member
Call Progress and ask them to custom rate a set for you.
Old Feb 4, 2010 | 07:22 AM
702Prodigy's Avatar
I was gonna look into Progress coils. I may even try out H&R coilovers again. Anybody heard of B&G coilovers. Adjustable height with out decreasing shock travel with a lifetime warranty. These coilovers were getting popular on VWs. The thing is, these coils with a lifetime warranty go for $1000. I guess gotta pay to play!
Old Feb 4, 2010 | 12:24 PM
dandaman15's Avatar
Community Builder
Yes, although they are not very popular on Hondas they are good coilovers.
Old Feb 4, 2010 | 12:27 PM
I personally went with AMR when I wanted full shock travel but they costed me a pretty penny, they also have lifetime warranty and their machining and craftmanship is top notch. If you are interested in going with them pm me and I can get you the "808 special" even though your in Vegas!
JDM Lyfestyle
Suspension & Brakes
26
Feb 10, 2009 08:37 PM
jaykun
Dec 12, 2008 11:37 AM
edger8cer
Suspension & Brakes
Nov 6, 2005 11:50 AM
redDAinteg
Aug 5, 2005 01:17 AM
ACR
May 4, 2003 12:35 AM
