need alittle help
Old Feb 2, 2010 | 01:35 PM
josh7owens's Avatar
Default need alittle help
I got a 91 crx with a d16z6 swap done. although the motor mount they used didnt fit right and the motor moves around alot. What motor mount do I need to get?
Also The wiring job was horable who sells wiring kits to wire a z6 into a si crx? I have stray wires running all over the place.
Old Feb 2, 2010 | 07:01 PM
8dxhatchy8's Avatar
Default Re: need alittle help
might want to hit up rywire.com and what mount are u talking about?
Old Feb 2, 2010 | 08:07 PM
alscrx's Avatar
That motor uses stock crx mounts.
ALso, there is no wiring kit for that...you use your original harness with couple wires for vtec.
Simply get some wire loom and clean that mess up....
Post pics
Old Feb 2, 2010 | 08:41 PM
josh7owens's Avatar
Post pics
Ill take pictures tomarrow to show you guys, its a mess. The other day it ran wierd and would run but as soon as you changed throttle position it feel on its face and lost all of its power. Well after looking around I noticed the knock sensor was unpluged. It's really that bad.
The motor mount that is on the driver side moves around in the motor mount. Its like the mount is to thin (not wide enough) to fill up the whole gap and it allows the motor to move.
I'll get them pictures to better explain.
Old Feb 2, 2010 | 11:16 PM
hatchet_honda's Avatar
sooo the drivers side mount is skinny? whats the rubber inside look like? who did this swap anyways?
Old Feb 3, 2010 | 08:49 AM
8dxhatchy8's Avatar
sounds like theres no rubber bushing....just the metal mount...
Old Feb 3, 2010 | 08:51 AM
JDhondaRI's Avatar
Did you switch bracket from your old head onto the z6 head ?
Old Feb 3, 2010 | 08:53 AM
JDhondaRI's Avatar
Post pics
Also Boomslang has a kit for obd0 dpfi to obd1 mpfi
xaine
16
Apr 11, 2009 08:35 PM
flatblk
Jan 23, 2006 09:05 AM
h3avyarms
Dec 16, 2004 12:44 PM
CRX_GUY_123
Mar 2, 2004 04:33 PM
RC_SKUBY
Dec 26, 2002 08:40 PM
