help....h&r sport springs..
Old Sep 5, 2002 | 03:22 PM
xXx Justin xXx's Avatar
Default help....h&r sport springs..
i have had coil overs on and lowered about the same as ebach sportlines. these springs make my freakin car look like it is stock ride height? wtf is up. the specs read that they are a hair lower then the sportlines. i haven't even put the rear on yet, i drove up and down my driveway. are they going to set? they are about to come off..
Old Sep 5, 2002 | 03:27 PM
HatchBox's Avatar
Skoobie no more...
Default Re: help....h&r sport springs.. (bstdvtecRx)
well i dropped my car and we got 3 of 4 done...lowered it down and we could barely tell it was lowered...but when we did the 4th and dropped it down.... success it was lowered...i have the same springs and it looks pretty good
Old Sep 5, 2002 | 04:31 PM
the DR.'s Avatar
Default Re: help....h&r sport springs.. (xxkenyon419xx)
do you know exactly what springs you have? because there are 2 different ones OE Sport and Sport, the regular Sport springs dont drop that low anyways (1.5 - 1.75")
Old Sep 5, 2002 | 05:36 PM
Dru-Si's Avatar
Default Re: help....h&r sport springs.. (CIVICtypeS)
I have H&R Sport w/Koni Reds, and it was dropped close to 2" all around. Check the part # and verify at www.hrsprings.com.
HTH
Old Sep 5, 2002 | 07:32 PM
Default Re: help....h&r sport springs.. (Dru-Si)
ok, well the box it was shipped in (on the white ticket) says item number 51807. the actual H&R box says 51807. the oe sport part is 51807-55, the regular sport is the # i have, and those are the specs i read when i lowered it, but it doesn't seem like that is the drop i have? i hope they will just set and lower a little more. tell me how low yours is.
Old Sep 5, 2002 | 07:49 PM
Brandon Chun's Avatar
The OEs drop is barely noticeable, only if you are parked next to a stock height car. I had the sports there is no wheel gap at all you can definately tell it is dropped esp once the springs settle. I would guess about a 2" drop.
Old Sep 6, 2002 | 08:42 AM
Default Re: help....h&r sport springs.. (Brandon Chun)
yea i have the real sports, no the oe's.....you say no wheel gap at all, how long did it take for them to settle all the way? and what size wheel and tire are you running. i have 13" steelies on it, but i also have some 205-40-r17 that i haven't put up on there since these springs? thanks
Old Sep 6, 2002 | 08:48 AM
ijjz's Avatar
Have pics of that set up? I'm interested in what they look like. Thinking about buying a set.
Old Sep 6, 2002 | 11:14 AM
HatchBox's Avatar
Skoobie no more...
Default Re: help....h&r sport springs.. (ijjz)
same with my car i have the sport (Not oe) and my car has about a a pinky finger of gap ...and its only been 2 weeks so they might not be settled all the way yet
Old Sep 6, 2002 | 11:17 AM
HatchBox's Avatar
Skoobie no more...
acuall the drop is 88-91 - 1.9 Inch Drop (FR) & 1.8 (RR)....
and also my car is dropped on them..and it looks really good i did it about 2 weeks ago and i have about a pinky finger worth of gap...replaceing the struts also sets it a little lower as well.
Old Sep 6, 2002 | 11:18 AM
HatchBox's Avatar
Skoobie no more...
acually the drop is 88-91 - 1.9 Inch Drop (FR) & 1.8 (RR)....
Old Sep 6, 2002 | 11:19 AM
HatchBox's Avatar
Skoobie no more...
sorry for so many posts i tried to edit and it just put it as another post
Old Sep 6, 2002 | 07:58 PM
the DR.'s Avatar
i dont really know, i just pulled that info off the H&R site
Old Sep 6, 2002 | 08:08 PM
HatchBox's Avatar
Skoobie no more...
well thats werid the place i got them lists them as that...
Old Sep 7, 2002 | 11:52 AM
HTH
ok, so still not sitting low at all, everywhere the part number is listed it is the right number (regular sport), but i sthere anyway that i could have the wrong spings in that box. what are the numbers for the spring rates on the actual springs. anybody know this.
Old Sep 7, 2002 | 12:17 PM
REDBARON's Avatar
Here's a couple of pics. This is H&R Sport springs with KYB GR-2. It's a good clean drop.
Old Sep 7, 2002 | 03:26 PM
Default Re: help....h&r sport springs.. (REDBARON)
ok, well i know i have the right springs now, i went and looked at the springs, they have the part number on them. 51807 i believe. i know they are the number fot the sport and not oe sport. my back struts are blown and so the front is sitting higher than the rear, but i guess i am going to have to just wait until they settle?
are those 16"? mine is sitting way higher than that with my 205-40-r16 on .
[Modified by bstdvtecRx, 12:27 AM 9/8/2002]
Old Sep 13, 2002 | 11:47 AM
HatchBox's Avatar
Skoobie no more...
how about a pic?
Old Sep 13, 2002 | 02:23 PM
martini's Avatar
yeah, they definitely will settle.
My brother put on some OE sports on his del sol, and when we got the tires back on, and took it off the stands, it looked like it was stock...
now I can rub the wheels when autocrossing.
Old Sep 14, 2002 | 10:38 AM
REDBARON's Avatar
Default Re: help....h&r sport springs.. (martini)
Yes those are 16's with Nitto 450 w/ 205/45/R16.
Old Sep 19, 2002 | 08:30 PM
MisterB's Avatar
whats the spring rate on the sports?
Old Sep 20, 2002 | 11:28 AM
HatchBox's Avatar
Skoobie no more...
Default Re: help....h&r sport springs.. (cl4show)
The sport springs for the 88-91 CRX/Civic are 350lb/in front and 250lb/in rear
Old Sep 20, 2002 | 01:02 PM
MisterB's Avatar
thanks do you happen to know what it is for the race springs
integratuner94
Suspension & Brakes
11
May 13, 2005 11:16 AM
weakGOODJunKieS.com
Apr 8, 2003 03:22 PM
oldbeefcake
Jun 5, 2002 07:22 AM
TypeR892
Aug 18, 2001 06:18 PM
