Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Cr-v propeller shaft UV joints.
Old Feb 2, 2010 | 08:18 AM
jdmotorsports's Avatar
Default Cr-v propeller shaft UV joints.
Thought I would post this for people. If your like me and have a higher mileage crv with failing UV joints then this is for you. No shop around my area has a solution, only to replace the shaft at 400$+. Did a little research and found http://www.rockforddriveline.com. They sell the replacements for about 30$ each. Saved me hundreds of dollars. I told my guy at the driveshaft shop and he is going to use them now. It was a pita to get them our, but nothing a BFH and some elbow grease didn't fix.
Old Feb 2, 2010 | 05:08 PM
newby_j's Avatar
Needs More Cowbell
Default Re: Cr-v propeller shaft UV joints.
Are you ordering a set? I was curious to see the brand and part number. Wondering about what it originally fit or if it is CRV specific
Old Feb 2, 2010 | 10:44 PM
qwrty's Avatar
is it the same as this:
http://www.autozone.com/autozone/cat...questid=433582
Old Feb 3, 2010 | 12:37 AM
newby_j's Avatar
Needs More Cowbell
no. that is a carrier bearing, the universal joints are not replaceable on the stock drive shaft. I think that a new drive shaft is $750ish from honda.
the op is talking about this:
Old Feb 3, 2010 | 02:07 AM
qwrty's Avatar
owww..
i see, well i call it a cross joint..LOL
i have a spare prop shaft that i replaced from my other V,
thats the problem that it encountered, and yes the solution
for it was to replace the whole thing.. someone told me that
theres a place near me that does rebuilding of those prop/drive shafts
i just have to locate it, so incase something happened again, i already
have a back up one....
Old Feb 4, 2010 | 07:23 AM
Yeah, the center bearing is the carrier bearing. Those hardly EVER die. I'm talking about the ones at each connection point.
They are already ordered and installed. My dad did the work for me while the wife and I were on vacation, so no pics. It was about 70$ shipped. These joints, unlike the oem ones come with grease fittings(though my dad used normal ones instead of the weird ones that came with them). He said he used the press and was able to easily get the old ones out. The new ones stay in with clips.
Old Feb 4, 2010 | 05:55 PM
Crx Jimmy's Avatar
rockford drive line makes good stuff. they make their own products. I used them to get U joints for a honda atv that honda only sold as a complete axle unit. Im sure you wont have any problems with them
Old Feb 9, 2010 | 03:16 PM
xzodiackillerx's Avatar
I just ordered mine.. I need a flange that goes on the trans.. when my ujoint went pop it took part of my flange with it.. I am going to try to weld it but IDK how to weld so it will be an exp.
Old Feb 10, 2010 | 07:19 AM
Crx Jimmy's Avatar
I would take it to a shop to weld it. I believe its cast. its hard to weld properly, if you have never welded before this isnt something to start with to try. it has to hold the u-joint properly and might need machining after being welded as well.
Old Feb 12, 2010 | 06:17 AM
yes it is a cast steel ... I am not going to weld it now .. I have a friend that will do it for me ... he is a professional welder
Old Apr 6, 2010 | 08:27 AM
Jorsher's Avatar
Awesome, so is that what could be causing this CRV to randomly shake from the passenger side while accelerating for a second or two?
BTW, OP, your avatar is EXACTLY like the one I made a few years back (apparently others have found/used it), and I was banned here for a while because of it...I think by Mr Pony...fortunately one of the admins noticed it was ridiculous and unbanned me.
Old Apr 6, 2010 | 05:53 PM
Ross 2.0's Avatar
In a Junkyard near you.
It's probably the front drive shafts. Mine is doing that too.
Old May 1, 2010 | 08:45 AM
EG MikE's Avatar
I am looking to get a awd 5 speed 1999 crv.. I was told the ujoint is not in good shape, what do you guys recommend I look into?
Old May 1, 2010 | 11:44 AM
Crx Jimmy's Avatar
Replace them with the Rockford driveline ones if they are bad.
Old May 1, 2010 | 09:14 PM
qwrty's Avatar
can they still fix if the prop shaft was already in 2 pcs???
its already dismantled from the joints, thats why i had to
look for a full shaft....
Old May 6, 2010 | 08:08 AM
EG MikE's Avatar
Gonna be ordering one for the rear on my car
Old Oct 11, 2010 | 10:48 AM
flossie127's Avatar
I had the same problem and lemme tell you, though the prop shaft was already in two pieces it can still be fixed.
__________________
honda crv parts
Old Oct 16, 2010 | 04:23 AM
Cory man's Avatar
Honda says this is normal for the 97-00 Crv's. I had an 01 that did the same thing and the "official" cause was due to driveshaft angle etc. The official service news:
This CR-V Vibration Is Normal
On ’97–00 CR-Vs (A/T and M/T), a shudder or
vibration during hard acceleration and usually in 1st
gear is normal. The vibration is related to the angle of
the driveshafts and the torque being applied to them.
All CR-Vs share this characteristic.
hth
Old Apr 23, 2012 | 12:13 PM
Mpasa's Avatar
Help me,what is the specs for UV joints prop shaft 97 crv.The dealer asked me the cap sizes which i dont know either.I have dismantled the shaft and woud like to replace UV joints
acco
Jun 29, 2010 10:14 AM
SolAssassin
Transmission & Drivetrain
Jan 24, 2010 07:39 AM
AdReNaLiN
Oct 16, 2008 08:51 PM
alexdog69
Apr 3, 2007 04:08 PM
Jaskula1
17
Jan 4, 2004 07:33 PM
