How does this budget motor setup sound!
Old Feb 2, 2010 | 12:19 AM
bauergold's Avatar
Default How does this budget motor setup sound!
Block:
B20 stock 84mm bore
12.0:1 JE pistons (got these and the rods for $125)
Shot peened LS rods with ARP bolts
Head:
Stock port B16 head
Blox dual valve springs (possibly going crower)
Blox Ti retainers (possibly going crower, bidding on some)
Toda C cams (looking at these for $300)
Exhaust:
Rage racing header
3" exhaust with a magnaflow muffler
Intake:
Stock ITR intake mani
68mm TB
3" short ram with a bpi v-stack
Fuel:
440cc injectors
255lph pump
ECU:
Crome dyno tuned
Let me know what you guys think, and recommend whatever you think would be good for the setup. Remember, I am a jew when it comes to buying parts lol.
Old Feb 2, 2010 | 07:48 AM
crazydominicanman's Avatar
Default Re: How does this budget motor setup sound!
Sounds like you have it all figured out to me. Be watchful of who assembles it and the tuning.
Old Feb 2, 2010 | 08:41 AM
092eg6's Avatar
maybe just bore out the ITR manifold to match the 68mm tb
Old Feb 2, 2010 | 01:05 PM
negusjuda's Avatar
lol thats nut much of a budget build if its all bought brand new
Old Feb 2, 2010 | 06:43 PM
damagedone27's Avatar
Thats the wonderful thing about buying used parts. granted it has its pros and cons. - One thing that i would do is put a golden eagle block guard in if you plan on reving the motor out - you can usually find those brand new for around a 100 bucks
Old Feb 3, 2010 | 03:26 PM
bauergold's Avatar
Couple changes up in the build.
Through a couple people that have built B20/LS vtecs, they recommended me NOT to run je pistons on the stock rods. I sold the setup for more than I got it for, so whatever lol.
Gonna go with YCP's ITR replica 84mm pistons on the stock rods with ARP bolts.
I also got the rage racing header for mad cheap. ($150)
The guy that I wanted to get the Toda C's from sold them fml.
Might go with some Blox B's if I can't find something else for cheap as hell.
What do you guys think about the Blox Bs?
Anyone have the specs on these? I am looking.
Also, bought the main item of the swap. Got a B20 longblock today for a laptop trade and $80. Haven't used the laptop in about 7 months and was gonna give it to my brother, so I basically got the B20 for $80.
If anyone in Socal wants a PasswordJdm bought complete head with the intake mani and exhaust mani, let me know. PM me!
Old Feb 3, 2010 | 03:35 PM
93egSLEEPER's Avatar
i wish my "budget build" consisted of a parts list like that.
Only thing that stands out to me is the 3" exhaust. IMO a bit big for NA. remember small displacement motors need some back pressure to produce torque.
Old Feb 3, 2010 | 03:51 PM
bauergold's Avatar
I don't think my build is overly expensive. I am buying pretty much no new parts except the pistons lol. I'll try to find those NIB too. lol
The 3" exhaust will be needed when I do the nitrous tune up on it. Want some 11s with a 4 door DA. I think I should attain that goal relatively easy on a nice 80-100 shot tune up.
Gonna see what I can get it with it all motor first.
Old Feb 3, 2010 | 04:14 PM
negusjuda's Avatar
im curious to why someone told you not to run je pistons on stock rods did they give you a reason
Old Feb 3, 2010 | 05:08 PM
bauergold's Avatar
They said they are too heavy for the stock rods.
Old Feb 3, 2010 | 05:20 PM
negusjuda's Avatar
that sux then thats what i was gonna do now im gonna have to get eagle rods another 400 bucks lol
Old Feb 3, 2010 | 05:29 PM
Natural Aspirations's Avatar
OEM pistons and pins probably weigh more.
Do you know the weight on the JE's?
B16's and pins are roughly 300gr
Old Feb 3, 2010 | 06:03 PM
negusjuda's Avatar
my srp's are 313 grams not sure if thats with the pin but on srp sight it says 313 grams
Old Feb 3, 2010 | 06:11 PM
negusjuda's Avatar
also i would like to know if i get eagle rods do i need to get diffrent bearings i got standered sized acl bearings because i was gonna use my oem rods
Old Feb 3, 2010 | 07:31 PM
bauergold's Avatar
I have heard that they are about 450gr
Old Feb 4, 2010 | 02:18 AM
negusjuda's Avatar
well unless the pin weighs another 140 grams i know on the srp/je sight it says 313 grams im gonna give them a call in the morning and find out for sure but i was told by someone that actually called them and asked if the ycan use there pistons on oem rods and they said its fine
Old Feb 4, 2010 | 11:41 PM
bauergold's Avatar
Just got some eagle rods and some YCP B20 race pistons. Also got an ACL race bearing kit. Bottom end should be good to go!
Old Feb 5, 2010 | 12:23 AM
komat's Avatar
3" is never too big
such a big myth about losing tq going from 2.5 to 3"
Old Feb 5, 2010 | 04:19 PM
bauergold's Avatar
Here are some pics of the B20:
The whole motor. Dad's 67 camaro on the left and my 68 barracuda on the right.
The b20 head looks great. Cams look brand new. Too bad I won't be using this head lol.
What it should look like when I'm done if I don't mess it up lol.
Old Feb 5, 2010 | 05:11 PM
komat's Avatar
is it me or none of those bolts from the engine stand to block is tighten up all the way or you using hte wrong length?
Old Feb 5, 2010 | 09:17 PM
bauergold's Avatar
Using long *** bolts. Hopefully it's okay!
On a side note, picked up a B16a head as complete as it gets today for $400. Intake mani, tb, dizzy, vtec solenoid, valve cover were all included.
Old Feb 5, 2010 | 10:56 PM
Meister vtec's Avatar
going from exotic supercars to a 335i would be a budget car for some millionaire,
sounds like the case is similiar to your story,
I mean a 67 camaro,a 68 barracuda,fukc tell me there numbers matching too and Ill cry!
My dad had a 1982 Volvo stationwagon,bought it used and kept it for 15 damn years!
now picture my budget build!
Old Feb 6, 2010 | 03:24 AM
negusjuda's Avatar
lol x2 thats what i said in a diffrent post nothing budget about this build this is a normal build but to be honest b20vtec builds arent really that expensive if you d oresearch and not just run out and get the most expensive parts you can find like a buddy of mines did. plus if your doing all the work that saves you a ton of money because labor is what kills you. but either way it seem like its going to be a pretty nice build im just waiting for my srp pistons and eagle rods to come monday and im gonna start putting my b20 together
Old Feb 6, 2010 | 10:37 PM
bauergold's Avatar
My dad has had the camaro since he was 15 and bought it for a whopping $500.
I got the Barracuda for free from my grandpa because he wanted to get it out of his yard. It had been sitting in his yard for 20+ years. lol
The Barracuda is also far away from running condition and has some body damage. It's a slow moving project. haha
Everything is bought off of craigslist so far. You guys would be suprised what deals you can find.
I just bought a B16 head that came with the TB, intake mani, fuel rail, FPR, injectors, dizzy, vtec solenoid, valve cover, and the complete head. Got it for $400. That is some good shopping right there.
A lot of people were posting up just the head with no valve cover and any of the other stuff for $375.
Just don't hop on the first deal you find either. I searched over 20 different heads lol.
Old Feb 6, 2010 | 10:45 PM
v8killaz's Avatar
nice setup
whop the hell pains their engine farmers red
