.20'' Over B20, Crower Stg3, B18, SPFab Radiator, Rims, PnP Head!
Old Feb 1, 2010 | 09:59 PM
cb07's Avatar
Default .20'' Over B20, Crower Stg3, B18, SPFab Radiator, Rims, PnP Head!
Got a list of parts for sale.
B20 block bored .20 over. Just got it from the machine shop today, still in bag, just took it out to take the pics and put it on my stand. Crank was polished (no grind needed), block bored/honed, recon main caps, block cleaned. Deck is straight and true no warping whatsoever. Perfect for a build N/A or Turbo. Will require 84.5mm pistons to be used. I will include a spare b20 block with a hole in it, spare block has oil pan, oil pump, timing gear. $300
LS B18 Head- Ported and polished on Intake and Exhaust Sides. Valve job done. Valley's were checked for warping, none was found. Head is perfect just needs to be cleaned and it's ready to go. It is disassembled but all parts have been bagged for reinstall. Has 8k miles on it since valve job/PnP. Took back off and torn down for supertech valvetrain, just never finished the project. $150
Crower Stage 3 LS N/A cams. Have 8k miles on them (came from above head). Lobes have NO scoring on them. I was going to run some emory cloth over the journals before reinstall just because I'm picky, but it's not needed. Badass cams for a N/A build. Part #BC0023-look up the number for specs on the cams. Must use titanium valve springs and retainers with these cams otherwise your pistons and valves will start making love as soon as you crank the motor. $250
SPFab 2'' Aluminum Race Radiator. BNIB, just took out for the pics. It is a half size radiator, made for a 92-95 civic, but the ports have been changed for a DA integra. Will still fit an EG civic though. $125
B18A1 Motor. 150k miles, had a snapped timing belt due to water pump failure. Block deck is VERY CLEAN. I was actually really surprised at how clean it was. Deck is flat, no warping at all. (I use straight edges to check my motors not my eyes). Head appears to be good but I can't say it doesn't have a bent valve, so my suggestion would be to check it. Very good motor to start a build with or slap together and drop in a car. $100
Passenger side headlight and turn signal for a DA integra. Signal is 92-93. Clean, no corner light. $30
Set of 17'' rims. Universal 4 Lug. 2 Good tires 2 Bad. They are painted green but you can strip them and paint them whatever. $250
All prices are OBO but I'm in no hurry to sell the motors so lowballs will be ignored. PM me here for inquiries please.
Sorry for my fail job at putting pics up the same size.
Old Feb 2, 2010 | 02:34 AM
aua_vtec77's Avatar
Default Re: .20'' Over B20, Crower Stg3, B18, SPFab Radiator, Rims, PnP Head!
do you have paypal?
do you ship to 33166
Old Feb 2, 2010 | 02:53 AM
Myroslav69's Avatar
Interested in the radiator, what can you do shipped to 44095? Business address.
Old Feb 2, 2010 | 05:18 AM
cb07's Avatar
Radiator is 125 shipped.
I will ship to miami. And yes, I do have payal.
Old Feb 2, 2010 | 05:28 AM
cb07's Avatar
Kittah not included in sale of crank/b20 :D
Old Feb 2, 2010 | 10:40 AM
cb07's Avatar
Block pending
Old Feb 2, 2010 | 04:13 PM
cb07's Avatar
Rad pending. All prices are obo
Old Feb 2, 2010 | 04:24 PM
BtecY0's Avatar
pm'd
Old Feb 2, 2010 | 05:06 PM
cb07's Avatar
PM replied
Old Feb 3, 2010 | 04:36 AM
cb07's Avatar
Corner Light Sold. Make an offer on everything else I can only say yes or no.
Old Feb 3, 2010 | 05:09 PM
cb07's Avatar
bump for a fresh motor plus more
legomytego
Mid-Atlantic (Sales)
Sep 4, 2008 02:09 PM
existanzcivicb20
Feb 15, 2006 10:15 AM
CoreyR
Aug 19, 2005 04:06 PM
bsemeyn
Sep 30, 2003 06:15 AM
luckyjun127
Jun 21, 2003 03:09 AM
