itr/ctr valvetrain limits
Old Feb 1, 2010 | 09:08 PM
Slow_import's Avatar
Default itr/ctr valvetrain limits
searched but didnt get a definite answer, whats the limits on the stock itr/ctr valve train?
Whats the biggest cams i can use before having to upgrade the valvesprings and retainers?
i've seen alot of builds running s2s2's and blox b's on the stock itr valvetrain, even some with pro1's. Didnt know how long it lasted but just curious if its fine.
if i were to use s2s1 or bloxA's how high can i rev it and still be safe? same with s2s2's and blox b's?
Old Feb 2, 2010 | 05:53 AM
GagnarTheUnruly's Avatar
Default Re: itr/ctr valvetrain limits
Stock ITR springs bind at 11.7 mm, I believe. I can't imagine anyone using S2s2s or Blox B's on that valvetrain for long...
Confirmed here:
http://www.team-integra.net/forum/di...g+Common+Topic
Old Feb 2, 2010 | 11:23 AM
95 integra's Avatar
High Lift + High RPMs = No good. I certainly wouldnt try to run a Stage II cam (of any brand/sort) on stock ITR valve train.
Old Feb 2, 2010 | 11:34 AM
93egSLEEPER's Avatar
Anything after a stage 1 cam (which is usually about the same profile as a set of ITR or CTR cams) requires upgrading in my books. Im going to run ITR cams in a stock B16 head and rev it a bit, kinda risky but at least its all oem parts. IMO build it.
Old Feb 2, 2010 | 02:31 PM
If those bind specs are legit there are even some stage 1 cams that can't be safely run on ITR springs.
Old Feb 2, 2010 | 05:51 PM
00Red_SiR's Avatar
All Motor Mentor
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/spring-test-bvtec-1803606/
The charts and pics are down but the information you're looking for is still there.
Old Feb 2, 2010 | 06:04 PM
mar778c's Avatar
Community Builder
Community Influencer
11.7 mm of lift or greater on a ITR valvetrain is a recipe for disaster. You will most likely experience a coil bind related failure. Also, rev limits and rpms are not nearly as important as lift.
crazihobo
Oct 12, 2011 02:48 PM
mynameizstitch
10
Jul 14, 2009 04:50 AM
Azn Kenny
Aug 27, 2007 06:21 AM
Dammit_Dan_954
Nov 22, 2003 12:27 PM
JDMCRX
12
Oct 12, 2001 05:19 AM
