Wrong ECU, runs better than stock ECU
Old Feb 1, 2010 | 08:54 PM
Choy's Avatar
Default Wrong ECU, runs better than stock ECU
so ever since i've had my EF si i have been running a pr4 ecu, i have a d15b7. I bought a pr6 and when i plugged it in to run my car. my car wouldnt drive. what could be the problem?
Old Feb 1, 2010 | 09:11 PM
crx_si-r's Avatar
Default Re: Wrong ECU, runs better than stock ECU
what is a "PR6" or did you mean a "PM6?" it could be that your old ecu was bad. have you tried swapping in another PM6 into your car?
Old Feb 2, 2010 | 05:10 AM
EJ1_Sleeper's Avatar
i think he means po6. the pr4 has a Ls map which would run better than the stock po6. Im assuming your converted to obd1? if not then you mean PM6 which would run like **** on a b7 cause its obd1 and the ecu is obd0. we need more info to help you out.
Old Feb 2, 2010 | 08:01 AM
Choy's Avatar
Oooooo lol i didnt know that. so a b15b7 is a obd1? and if i were to swap a gsr obd1 would i have to change any plugs? im sorry im just learning about cars.
Old Feb 2, 2010 | 08:11 AM
Josueneta's Avatar
well my friend has a D16y8 on his Dx Ek but hes runing a B16 ecu on it it revs up to like 8400 and some times he puts the si ecu on and it revs almost the same but it back revs way better
Old Feb 2, 2010 | 12:32 PM
35r'DHyBriD's Avatar
................... LEFT FIELD
But you would need some harness work to swap that GSR in unless u run single harness and vtec sub with a jumper to obd1
Old Feb 2, 2010 | 07:21 PM
ef yu's Avatar
NOT TRUE!!!!!!
i have a D15b7 in my crx and im using a PM6 ecu. runs like it should. passed smog and everything.
i used the OBD0 distributor and OBD0 ecu.
If you tried to start an engine with converted obd1 plugs at the distributor plugs and using a OBD0 ecu. it just would not start.
SpeedOFsmell
Jul 25, 2012 03:31 PM
B18dego
Engine Management and Tuning
Apr 7, 2012 06:28 PM
ev94eg
Sep 25, 2011 09:45 PM
FOMULA91
Jul 18, 2005 01:31 AM
drvfast
Apr 4, 2004 09:18 PM
