What is the good word on tires...
I am shopping for some new street tires and as of right now I am open to some suggestions. For the last two years I have run Falken Azenis. I thought they were okay for the most part. I thought they had good grip for a road tire, but the downside to them are the excessive road noise, they almost have no give over sharp bumps, and they completely suck in the rain. So I am looking for something new.
I would like a tire to fit these parameters:
-16 inches
-between 205 and 215mm
-40 or 45 series
-and less the 23.9in tall mounted
Any input would be appreciated.
-16 inches
-40 or 45 series
The new generation of extreme performance tires is here, and they're MUCH better than the Azenis in every way. They are:
Dunlop Direzza Sport Z1 Star Spec
Bridgestone Potenza RE-11
Kumho Ecsta XS
Yokohama Advan Neova AD08
Toyo Proxes R1R
Hankook Ventus R-S3 Z222
(Falken will soon introduce a replacement for the Azenis, called the RT-615K.)
The RE-11 and R1R are available in 205/45-16; the XS is available in 215/45-16. The XS is a bit worse than the rest of this group in rain, and since that is clearly important to you, I would get one of the others. (Road noise tends to be a function of tread depth more so than one tire over another.)
Bottom line, I think your best bet is the Bridgestone Potenza RE-11 in 205/45-16.
Kumho Ecsta XS
Toyo Proxes R1R
I was interested in the Direzza Sport Z1 Star Spec, but they were not available in my size. I really wanted to give the Advan AD08 a try because of my experience with the Advan AD05/06. Life is hard when you roll in 16's and you want new soles for your shoes.
I haven't really heard anything about the RE-11, but if is anything like the RE-01R... I might be interested.
It's a much improved replacement of the RE-01R. There's a side-by-side comparison test on the Tire Rack website of the RE-11, AD08, XS, and Star Spec. (Bottom line, all four perform admirably and similarly on dry pavement; the XS is a bit worse than the other three in rain.) You'll also find some good comparison comments by Andy Hollis in this topic.
are you looking at just dry traction grip? When I buy tires I look at wet & dry traction, road noise, and longevity. Dry traction is the 1st thing I look at and then compare the wet traction. Weigh the factors and start comparing the other aspects of tires. IMO General Exclaim UHP are a great all around tire. Check them out.
The General Exclaim UHP is a cheap, longer-lasting summer tire that isn't even as good as the best tires in that lower-performance category (such as the Yokohama S.drive). That is a TERRIBLE recommendation for someone looking for an "extreme performance" tire to replace the Azenis.
Rayz_Si
Apr 28, 2008 03:35 PM
Sohc Driver
29
May 22, 2002 03:28 PM
