Question about using DC2 LS/GSR rear brakes
Old Feb 1, 2010 | 05:14 PM
Nihilus's Avatar
Default Question about using DC2 LS/GSR rear brakes
I have a 1990 CRX Si. So from what I have read in the faq's and whatnot about converting to ITR 5-Lug, I've seen that pretty much the entire rear trailing arm assembly simply bolts onto the chassis with no modding. My question is this: will the rear trailing arm assembly from a 94-01 LS Integra or GSR swap over to my chassis as well? I'm in a situation where I am able to get my hands on the entire rear trailing arm assemblies from a 94 LS and would like to swap them onto my CRX for the bigger brakes.
Just so there are no misconceptions I will state my question again: will 94-01 Integra LS rear trailing arm assemblies (including brakes) swap onto my 1990 CRX Si and if any mods are required what are they?
Thank you in advance.
Old Feb 4, 2010 | 04:05 PM
Nihilus's Avatar
Default Re: Question about using DC2 LS/GSR rear brakes
Anyone...?
Old Feb 4, 2010 | 04:13 PM
em1pusha99's Avatar
i think you use the trailing arms from 94-01 teg, and you use all your stuff like the lower control arm, upper control arm, then it's a direct swap
Old Feb 4, 2010 | 05:31 PM
claymonthug's Avatar
i did a swap with 91 teg brakes/prop valve/ and brake boost. i used everything on the integras TA except for parts used for alignments. apparently everything up to 01 (including type-r) will pretty much bolt right up. your probably gonna need to run the ebrake cable from the teg tho. i suggest changing your booster and prop too (big diff)
Old May 19, 2010 | 02:00 PM
Nihilus's Avatar
Bringing this thread back from the semi-dead. Anyway, I've gotten my hands on 94 Integra RS rear trailing arms including calipers. So I'm going to end up using the 94 Integra e-brake cables, yes? Also, being an RS Integra with no ABS I decided to pull the master and booster out to swap into my CRX but I still need to get a DA prop valve. Does it matter between auto/manual prop valves? So in the end my setup is going to be 94 Integra RS rear brakes and e-brake cables, 94 RS master and booster, and DA prop valve. I'm assuming this setup should work, yes?
Old May 21, 2010 | 02:08 PM
Nihilus's Avatar
bumpitty?
Old May 21, 2010 | 02:28 PM
rallypoint_1's Avatar
All that stuff(TA, prop valve, MC, BB) will work. E brake cables will work too but they are a little long for the CRX. Your going to have to tuck them in a little. If the TA bushing or any bushing is bad, replace them before the swap.
Loserjerk57
Jul 19, 2018 05:53 PM
jacksonww
Oct 5, 2010 05:09 AM
asianflava
Dec 8, 2008 11:14 AM
spcrxracer
11
Jun 29, 2005 10:02 AM
racecarpete
Jul 17, 2003 08:24 PM
