..::98-00 Spec ITR B18C Full Swap For Sale!::..
Old Feb 1, 2010 | 05:04 PM
04ep3hatch's Avatar
Default ..::98-00 Spec ITR B18C Full Swap For Sale!::..
Up for grabs is my COMPLETE 98-00 Spec JDM ITR B18C swap. I purchased the swap from Hmotorsonline (http://www.hmotorsonline.com/shop/sc...age&item=30011) for $4600 with paper's. Hmotors claim an average of 17K miles, i've put about 15,000 on it since i got it, with no problems. Swap is 100% legit and need's nothing to run. No leaks, anything. Car come's with PWDJDM whale dick intake, stock JDM itr header w/ heatsheild, Innovative polished EK mounts, Competition Stage 2 clutch, OEM B-series shift linkage w/ short throw, autozone special axles(just replaced), OBD2A VTEC engine harness, P28 ecu fully tuned by Xenocron on ECTune Engine Managment, made 200.5hp. Motor is completely stock other than the bolt on's. Daily driver reliable. Oil changed with Royal Purple 5w40 every 3000 miles, runs perfect with no hickups, i will take you for a ride to prove this.
I'm asking 3500$ with everything listed, the $249 mounts, 199$ intake, $285 clutch, $800 for engine managment w/ the tuned ECU. $3500 is more than reasonable for the most legit swap your going to find. Drop your old D series out and bolt this in and go. Text me 5702288348
Old Feb 1, 2010 | 05:45 PM
goldhatch94's Avatar
Default Re: ..::98-00 Spec ITR B18C Full Swap For Sale!::..
how much for the motor and trans no ecu no mounts no intake pipe. and i dont need the clutch but i can use it
aeros's Avatar
what tranny is included?
Old Feb 1, 2010 | 05:49 PM
since he bought it from h motors i would guess 98 spec LSD R trans
Old Feb 5, 2010 | 08:23 PM
blade0314's Avatar
hey bro trade for this?
hey every1 i have a complete long block from a 2008 honda crv with only 30k miles on it the reason it was taken out of the car is because the original owner had a oil change done at a local jiffy lube and the idiots didnt tighten up the oil drain bolt and hence the oil drained out slowly luckily the lady noticed before the motor had any real damage done to it, all the motor needs is a new set of rod bearings and you have a fresh next to new k24, i am asking $1000 obo i am located in long island near jfk airport and i can be reached at 516 342 0318 thanks
what is included with the swap:
wiring harness
starter
exhaust manifold
intake manifold
post mount
vtec valve cover
Old Jul 25, 2010 | 11:15 PM
Killa Cam's Avatar
got 3 k!!! for ur complete swap!!
generation_D
May 12, 2011 08:17 PM
OTI-
Southeast (Sales)
Sep 14, 2010 07:08 PM
OTI-
Sep 14, 2010 07:07 PM
K20A_EH
Aug 13, 2009 04:53 PM
JakeFreeman
Jun 1, 2006 07:21 AM
