Converting EX sedan from automatic to manual
Old Feb 1, 2010 | 04:33 PM
90lxsdn's Avatar
Default Converting EX sedan from automatic to manual
Hey guys,
I just picked up a '90 ex sedan. The car is mint, but I am not a fan of the automatic trans.
I have a few questions:
1). Will the 5 speed transmission from the 1.5 civic (lx and dx) work in my 1.6l EX? If not, what transmissions are compatible with this?
2). If the transmission from the 1.5 isnt usuable in my ex, are all of the components? like pedals, cables etc...
Thanks
Old Feb 1, 2010 | 04:44 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Converting EX sedan from automatic to manual
1) YES
2) All of it swaps over.
Old Feb 1, 2010 | 04:54 PM
90lxsdn's Avatar
Originally Posted by 4drEF
1) YES
Thanks for the quick response! this is awesome news for me!
I know this is asking alot, but do you happen to know everything I will need to do the swap? I was thinking about just picking up a beat up sedan with a 5 speed just for the trans, but if I could save some space and gather the parts that would be better.
Also do you know if any fabrication will be needed, or will it just bolt right on?
Thanks!
Old Feb 1, 2010 | 05:28 PM
Clipsed's Avatar
need the peddle assembly, clutch cable, trans, and shift linkage.
Old Feb 1, 2010 | 05:39 PM
JDMefHATCH7's Avatar
i did it not too long ago on my hatch
you need the pedal assembly
clutch cable
shift linkeage
rear stick tranny mount that needs to be changed on the read crossmember towards the passengers side holes
its not that hard
hardest par is pedal assembly i would say...
just look for a good shifting L3 cable tranny and youre good to go...
Old Feb 1, 2010 | 07:48 PM
90_EX_Civic's Avatar
only thing i have to add is, if you don't mind the extra work(which seems like you don't cause you're doing this swap) is taking the tranny apart and swapping in a si/ex final drive. will give your car more pep.
*edit
unless you get a si/ex tranny, then never mind.
krisfnbs
Honda Civic (2001 - 2005)
Jul 21, 2013 06:05 PM
cmdr430
Honda Insight & CR-Z Hybrid
10
Jul 2, 2010 07:17 AM
brianjec
Nov 26, 2008 03:34 PM
StinkyTofu
May 9, 2003 02:25 PM
