Clutch problem bad noise
Old Feb 1, 2010 | 03:49 PM
93accordEX's Avatar
Default Clutch problem bad noise
Ok so here it goes, when i push on the clutch pedal down, the worst squealling noise, destroys my ear drum. it only makes this noise when the clutch pedal is down. though when in neutral at idle it makes a small humming squeallish noise. does any know what bearing or other porblem that might be? it also smells like clutch even in neutral. thank you for your time answering and reading my post, it is greatly appericated.
Old Feb 1, 2010 | 05:55 PM
davey5300's Avatar
Default Re: Clutch problem bad noise
most likely a bad throw out bearing. But I'd replace the clutch and pressure plate as well
Old Feb 1, 2010 | 08:17 PM
zimmy709's Avatar
throwout bearing or pilot bearing
Old Feb 2, 2010 | 04:40 AM
nus_dogg's Avatar
Accords & Preludes don't have pilot bearing like them Civics & Tegs.
Its gotta be the Throw Out bearing.
HondaMan_TypeR
14
Jan 6, 2009 05:21 PM
gofastgokart99
Sep 27, 2007 01:42 PM
JDMtype Eg6
May 29, 2006 03:45 AM
pa2play
Jul 28, 2005 09:42 AM
