opening the rear door with a handle?
Old Feb 1, 2010 | 01:49 PM
thomas998's Avatar
New User
Default opening the rear door with a handle?
The problem is the wife had the child proof locks engaged so no one inside the car can open a rear door... Add to that the outer door handle had broken and we now have a car with a rear door that cannot be opened.
Now I'm guessing that something has broken from the handle... But because the door can't be opened I can't remove the door panel to see what is happening inside.
Does anyone have any ideas on how to open the door when the outer door handle is broken and the inside handle is set to child proof? I've taken many a door apart but have never come up against this problem before.
Its a 2000 Accord EX 4 door.
Any suggestions are welcome.
Old Feb 1, 2010 | 07:13 PM
davey5300's Avatar
Default Re: opening the rear door with a handle?
you could possibly still pry out the door panel by opening the window and prying from the top. it's worth a try
Old Feb 1, 2010 | 10:55 PM
ricehead's Avatar
yeah, you'll have to maybe get a clothes hanger and try n use that to catch the latch inside the door panel to pull it open. that way you can pass that child proof lock. it helps tho is you have some reference as to there you want to start poking around. i think the easiest wy is just pay someone to open it up if u can afford it.
Old Feb 2, 2010 | 07:45 AM
Dannyvho's Avatar
You could remove the door panel of the other rear door: this will show you how you can reach the latch of the blocked door.
Mychal71
Mar 20, 2022 01:32 PM
kerri lyn vigil
Dec 7, 2017 10:16 AM
george1960
Jun 17, 2013 04:01 AM
Rayzorx
May 30, 2011 06:46 PM
mataliandy
Jul 12, 2010 06:24 PM
