B Series Swap:Which Rear Mount into A/T Civic
Old Feb 1, 2010 | 12:49 PM
bb4socal's Avatar
Default B Series Swap:Which Rear Mount into A/T Civic
Hello...im some very quick responses from of the pros. or anybody that might know:
My question: Which Rear engine mount do i use for a b18c1 swap into a Automatic chassis 92 Civic DX?
I will be converting vehicle into Manual Trans.
My options:
1. Use the stock automatic rear engine mount thats with chassis.
2. Use a Civic si manual trans rear engine mount from 92-95 civic hatch si
3. USe a Manual trans Integra 94+ Rear Engine Mount.
Please someone help me ASAP...i have an opportunity to by a integra rear mount soon, and dont want to buy it if i dont need it. Please help.
Thank u..
PLEASE BUMP! It will help
Old Feb 1, 2010 | 01:25 PM
canadaek's Avatar
Default Re: B Series Swap:Which Rear Mount into A/T Civic
Mounts: This is alot of hear say for what to use. This is what you need and why. First off you need an upper tranny BRACKET (not mount) from a 96-00 manual tranny because the auto one doesnt even fit on the tranny, go figure (Part #: 50825-S04-000
Next youll need the lower tranny mount off of a manual 96-00 car. Also you will need 3 bolts to go into the tranny as well as 2 that go into the chassis (Part #s: Tranny bolts: 90190-SR3-000 Chassis: 90166-SR3-000
And finally a REAR TRANNY MOUNT Because the auto and manual are totally different. Here is a pic to tell the different. If you use an auto one it wont sit right, although you can use the AUTO bracket on the manual tranny. Part#: 50810-SR3-030
read the sticky for auto to manuel swap has picture and everything
good luck
Old Feb 1, 2010 | 03:14 PM
bb4socal's Avatar
good luck
i think there is some confusion. i checked out the part numbers u suggested and it makes no sense. the "tranny bracket" will NOT work for a 5th gen Civic as i stated i was putting a gsr motor into. That bracket is only for EK 96-00 civics. Thats besides the point because i will be using a hasport auto to manual conversion mount for the transmission(92-95)
Second point.... u stated that for the rear mount, I should use a Manual (chassis) Rea mount. I checked that PN: 50810-sr3-030, and it relates back to 93-98 civic Manual only.
Can anyone else help confirm this. That i should use a 93-98 Civic Manual Rear Engine Mount?
My understanding was that i should use a 94-00 Inetgra Mount. This is why im confused and trying to get confirmation from other poeple that have done a bseries into a Civic, and especially a Civic that is going to be converted to Manual 5speed as well.
Old Feb 1, 2010 | 04:52 PM
Bizarre's Avatar
This picture may help. Got it from the ff-squad website so all credit goes to them. Anyways this diagram was created assuming your vehicle was a manual transmission model. So going by what it says as long as you use a d-series manual transmission motor mount and you should be good to go. I believe you will have an issue with the passenger side frame mount since it is located in a different position. Instead of removing it and rewelding the manual transmission frame mount in, there are companies that make a mount like Innovative that will help you out in this situation.
Info on their mount: http://www.innovativemounts.com/Prod...ductCode=49520
Old Feb 1, 2010 | 08:11 PM
bb4socal's Avatar
cool. thanks for the info! im just going to get a oem dseries manual rear mount and try it. Ill let u all know the results!
JGTW
Dec 17, 2018 03:12 PM
Your Name
Nov 1, 2009 01:23 PM
dem0nk1d
Jun 15, 2007 09:38 AM
wfocrx
May 17, 2006 07:46 PM
kin6david
Jan 13, 2004 12:10 AM
