DIY way to lock the cam gears? Belt replacement
Old Feb 1, 2010 | 11:53 AM
djnikko's Avatar
Default DIY way to lock the cam gears? Belt replacement
Hi all, im looking for any DIY methods of locking the cam gears in place whilst putting a replacement belt on a H22A (DOHC) engine? Please post up some ideas if you have some
Thanks in advance
Old Feb 1, 2010 | 12:12 PM
ironcheftony's Avatar
Default Re: DIY way to lock the cam gears? Belt replacement
I have used some locking vise grips with no problem
Old Feb 1, 2010 | 10:43 PM
worlds-slowest-EG's Avatar
Zip Ties FTW
Old Feb 2, 2010 | 04:40 AM
mikeymcm's Avatar
works good for me.
Old Feb 7, 2010 | 08:13 AM
djnikko's Avatar
Thnks guys, I used some cable ties in the end and it worked like a charm.
Old Feb 7, 2010 | 06:23 PM
tofast4uh22's Avatar
wow all these responses and not one is the correct one. there are two holes on each cam plate that leads to a indentation in the cam. the plate has two holes so that way the cam plates can change from intake to exhaust so you have to see which hole lines up with the cam when the cam is at top dead center. then you use a 5mm rod and put it through the cam plate, it sticks in the cam and locks them down.
Old Feb 9, 2010 | 09:17 AM
djnikko's Avatar
Yes but on the H22 engine these holes do not exsist from what I can tell? These camshaft holes mentioned in the manual are covered by plates on the H22. Can they be removed to reveal the holes? Or will that create a another issue?
Old Feb 9, 2010 | 09:41 AM
no there are holes in the plate that allow you to stick the 5mm rod threw the cam plate and lock into the cam.
on each cam plate there are two holes that go threw it, one hole will line up with the exhaust cam hole one hole will line up with the intake cam. so that the plates could be swapped and not have issues.
Old Feb 11, 2010 | 11:37 AM
djnikko's Avatar
Thats great, thanks for the tip. I know which way i'll be doing it from now on
Old Nov 17, 2017 | 06:38 PM
1996accord's Avatar
Icon4 Re: DIY way to lock the cam gears? Belt replacement
My h22a4 doesnt have those holes at all i know which ones are being described but mine is different and do not have them
Old Nov 19, 2017 | 04:48 PM
Doodasi's Avatar
Lol... There is the correct way, and there is my way. Dig through your wee bolt box, find the right size, and stick it inbetween the 2 cam gears where there is the smallest gap. The teeth will lock it in there.
Old Nov 20, 2017 | 10:48 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
They dont need to be locked. The tbelt jobs on those old Hondas are so easy I could do it half dead......
But if you must,zip ties work great.
Old Nov 20, 2017 | 11:50 AM
pogeeboy27's Avatar
^^^Agree. However if you really don't trust yourself or just want to get fancy, get this.
cadeMFjohnson
Apr 21, 2009 07:54 AM
Reis
Jul 20, 2005 02:44 PM
MaxSterling
Jul 11, 2003 04:16 PM
fastludeh22
Nov 20, 2002 07:38 PM
