obd0 to obd1 mpfi questions
Old Feb 1, 2010 | 09:58 AM
4g4dcruisin's Avatar
Default obd0 to obd1 mpfi questions
as of right now im running obd0 sohc zc in my 90 sedan. im looking into possibly a z6 and im not sure what i should do to wire the fuel injectors CORRECTLY.
so i have obd0 injectors/rail with the resistor box. when i get the obd1 ecu/plugs/rail, how do i wire everything up? would it be the same? i've talked to a couple people that said i can leave in the resistor box and use my same injectors but i'de like to do everything correctly.
Old Feb 1, 2010 | 10:30 AM
Clipsed's Avatar
Default Re: obd0 to obd1 mpfi questions
it is wired up correctly if you use the obd0 injectors and resistor box.
Old Feb 1, 2010 | 11:36 AM
funigui's Avatar
New User
if the injectors are obd0 they need a box, obd1 doesnt. The ecu can use either one.
Old Feb 1, 2010 | 11:51 AM
88crxhfzc's Avatar
New User
go to rywire.com get the obd0 to obd1 harness jumper and thats all u can use the stock injectors and fuel rail the harness comes with all the plugs u need for a z6 check it out
lilsicsoul
Mar 1, 2009 04:23 AM
atarigamer01
13
May 20, 2008 09:23 AM
91lsteg
May 15, 2005 11:32 AM
dpine
Jul 14, 2004 06:19 PM
