sohc zc motor questionc
Old Feb 1, 2010 | 04:59 AM
Kris's turbo's Avatar
Default sohc zc motor questionc
I have a 90 dx ef and I was thinking about putting in a sohc zc motor, do you think it would be ok if I leave it a 2 injector setup or do I need to rewire it to 4 injectors? Just curious if the motor would run lean, has anyone tried this? Im not looking for preformance just want to get my gas saver running.
Old Feb 1, 2010 | 05:54 AM
~sp33~'s Avatar
EFB055
Default Re: sohc zc motor questionc
It'll work fine. Don't expect big gains for a minute increase in capacity though. Most of the extra power comes from the engine having more efficient intake and exhaust manifolds (which you don't plan on changing).
Old Feb 1, 2010 | 06:47 PM
Thank you for your help, so if I run the 2 injector manifold I can use the 2 injector computer also?
Old Feb 1, 2010 | 07:23 PM
crx_si-r's Avatar
yes. it is literally a replacement motor. if you are not changing out your fuel management system you will be fine.
JibOnALib
Feb 14, 2005 05:27 PM
EsCo_EsCo
May 17, 2004 09:16 AM
