Suspension & Brakes Theory, alignment, spring rates....
4 lug type-r suspension????
Old Jan 31, 2010 | 02:59 PM
Rawl's Avatar
Default 4 lug type-r suspension????
so i've been looking for disc brakes to throw on my hatch
i came across this guy who said he had some
all around with polyurethane bushings and braided steel brake lines
he said they're off a type-r but they're 4 lug
i was under the impression type-r suspension came with 5 lug?
he said the obd 1 versions came 4 lug?
can anyone help me verify this?
thanks
Old Jan 31, 2010 | 03:01 PM
Adriano's Avatar
Default Re: 4 lug type-r suspension????
The older type R came with 4-lugs. It's 4x115?? It's not the same lug pattern as the standard civic.
Adriano
Old Jan 31, 2010 | 03:17 PM
jdmwannabee's Avatar
96 type r is 4 x 114
Old Jan 31, 2010 | 04:19 PM
.dave's Avatar
i HAS questions ?
Fast-brakes also sells replacement rotors for them (here). Previously I think it was a bit of a PITA to find rotors.
Old Jan 31, 2010 | 06:17 PM
97ej6dx's Avatar
I know accords and Preludes have that lug pattern but its doubt full the rotors work..> Although the NSX rotors fit on the 5 lug Type R (in front) so you may look in to the accord/prelude rotors
Old Jan 31, 2010 | 06:51 PM
.dave's Avatar
i HAS questions ?
I'm pretty sure they don't fit, I could be wrong though. I know some people have 4x100 rotors redrilled for 4x114.3. It seemed like too much of a pain to me back when I was looking for brakes, so I just went with a FastBrakes front/rear setup.
Old Jan 31, 2010 | 06:52 PM
no they will not work accords are "hub over rotor" and type r's are "rotor over hub"
Old Jan 31, 2010 | 08:55 PM
Rawl's Avatar
yea the guy im getting the setup from said the
bolt pattern is 4x114.3
he's throwing in some cross drilled rotors
so it everything for $250
sound good to me.
MykHonda
Apr 24, 2014 04:40 PM
Triker
Apr 10, 2012 12:57 PM
88 rex
Sep 12, 2006 12:52 PM
JDMorgan
Aug 4, 2005 04:27 AM
mstewar
Nov 6, 2003 06:46 AM
