Honda Heaven *Never Ending FS Thread Updated Daily*
DO NOT BUY FROM THIS SELLER...
SCAM: http://hondamarketplace.com/showthread.php?t=2757158
Finally decided to list all my parts into one HUGE thread after i just picked up so many uneeded parts in a car. Pretty much everything i have listed here i have listed on my ebay store so im willing to ship just about anywhere. Only trades im looking for as of now are GSR black interrior, 15" wheels with tires, del sol drivers seat and rear eg/dc struts, dc/eg k swap parts, 17" suv tires, wideband o2 with gauge, dc lca's and camber kit.
BUMP if viewed please!!
Sparco Evo Racing Seat SOLD
DOHC Vtec Valve Cover Powder Mint Green SOLD
GSR Skunk 2 Intake Manifold Polished with Gude/Bullfrog 65mm tb SOLD
JDM ITR Header SOLD
JDM Mesh Style Rare Wheels 15" 4x100/4x114.3 JWL (Japanese Light Weight Wheel Stamp) VERY LIGHT WEIGHT ( Fresh Gold Paint n Polished Lips) with Nankang 205/50/15 tires 80% tread BEST OFFER or trade for blades plus cash
http://en.wikipedia.org/wiki/JWL_standard
Civic/Integra Coilovers 88-00 Brand New SOLD
Earls Oil Filter Relocator Adaptor SOLD
Oil Filter Relocator $30
Oil Cooler Brand New $50
Aeromotive FPR w/ fittings and Marshall Shock Proof Gauge SOLD
Custom Made Long Tube Header Turbo or NA B16/B18, came off an 8 sec. drag car with T4 setup and two 45mm wastegates. I bought it for my NA setup and made a stainless downpipe that bolts up to the exhaust. $400
M&R 5 Point Harness Pink Brand New Dated 06/2007 SOLD
Apexi Super Ground Stabilizer slightly used SOLD
DVD Video LCD Monitor 2.5x3.5" Brand New $50
Lanzar Vibe 600w 240 amp & 410 amp SOLD
92-95 Civic Carbon Fiber Air Scoop SOLD
GSR Stock Header SOLD
Complete EG/DC AC Setup $150
Gearbox Racing Suit size 56 slightly used $75
94-01 Red GSR Spoiler SOLD
Del Sol Cargo Box & Rear Trim Make an offer on each piece you need
CF lookalike shift boot with mounting bracket and matching ebrake boot SOLD
Del Sol Tailights SOLD
Del Sol Gauge Cluster 116k SOLD
Del Sol dash with all vents minus $75
Del Sol Drivers Manual Mirror Black $20
Del Sol Windows/Glass/Motors (best offer)
Del Sol Targa Top Compartment Storage & Trunk Struts (best offer)
[IMG]http//img215.imageshack.us/img215/5541/dsc003770873538.jpg[/IMG]
Del Sol Door Trim/ Gasket Seals (both Sides)
Del Sol Targa Top Trim (3 pieces) & Headliner
Del Sol Turn Signal/Headlight Switch $25
Del Sol Windshield Wiper Motor $25
Del Sol Trunk Carpet $50
02+ Civic, EP3 & RSX Sprint Lowering Springs SOLD
97-01 Prelude SH Spoiler painted orange $40
H22 Spark Plug Cover painted red SOLD
H22/H23 5 Speed Axle passenger needs new boot. $30
CRX Euro Tails $25
SOHC Vtec Valve Cover painted blue with some scratches SOLD
92-95 Civic coupe drivers tail light $20
92-95 Civic coupe rear seats $40
Prelude/Accord Weapon R Short Shifter $40
92-95 Civic coupe oem side skirts SOLD
92-95 Civic trim, consoles, speaker covers, heater vents painted red (previous owner) $40
CRX Si Wheel $25
92-95 Civic Steering Wheel/Airbag $30
5psi wastegate spring SOLD
H22/H23 Thermostat NEW $10
02+ Civic, EP3, RSX 5 Speed Conversion $100
02+ Civic, EP3, RSX Brake Master Cylinder $50
02+ Civic, EP3, RSX Tie Rods (2 of them) $25 piece
P06 ECU SOLD
92-95 Civic Coupe Trunk Carpet SOLD
K20 EP3/RSX Alternators $40
H22 Top Timing Cover SOLD
B Series Top Timing Cover SOLD
92-95 Civic SRS Unit $25
97-01 Prelude Owners Manual $10
4G63 T3/T4 Turbo Manifold SOLD
92-95 Civic Coupe Black Interrior Carpet SOLD
GSR P72 Head SOLD
GSR Stock Cams SOLD
GSR Hydro Tranny SOLD
JDM P30 ECU (chipped for Type R Map with IHE) SOLD
92-00 Civic/Integra Adjustable KYB Struts w Eibach Springs SOLD
94-01 GSR Strut Bar SOLD
B Series Front Tranny Mount SOLD
GSR P72 AC Bracket Mount SOLD
B Series Top Hydro Tranny Mount SOLD
B Series DC/EG Drivers Mount $30
B Series Rear Tranny Bracket Mount SOLD
B Series Halfshaft SOLD
92-95 Civic EX/Si Rack $50
Del Sol Passenger Corner SOLD
94-01 Integra Ignition Harness $30
MINT 97 GSR Tranny SOLD
GSR Shortblock SOLD
92-95 Civic OEM Floor Mats SOLD
Side Skirt Clips (most hondas/acuras use these) $10
Del Sol Heater Blower $30
Del Sol AC Blower $30
Del Sol and possibly Civic/Integra Power Window Control $40
94-01 Integra Front Splash Guard (center is melted from header) $25
GSR P72 Flywheel w/ all bolts SOLD
92-95 Civic Ex Seats (drivers is missing cover and one of the brackets that the rail bolts up to) $50
Del Sol possibly Civic/Integra Rear View Mirror $10
92-95 Civic Coupe Stock Catback Exhaust (cat intacted and not punched) $75
Del Sol Rear Speaker Mounts SOLD
Del Sol Windshield Side Moldings SOLD
RSX Type S 310cc Injectors (plastic on one is chipped off but didnt affect anything when i ran them, can be used with B/D/H series if you're using an aftermarket rail) $100
B16 pr3 pistons/rod (set of 3) $75
Edelbrock Victor X GSR Bare intake manifold with 68mm opening tapered a bit for 70mm tb. SOLD
OBD2 to OBD1 Injector Harness SOLD
Hasport B Series EG/DC Mount SOLD
92-95 Civic/Del Sol SRS Unit $40
92-95 Civic/Del Sol Steering Wheel SOLD
K Series Fuel Rails (2 of them) $20 a piece
Manual Boost Controller $25
92-95 Civic/Del Sol Hood Latch w Cable $25
B Series GSR Crank Pulley (few chips) SOLD
TSX Intake Manifold SOLD
TSX Throttle Body SOLD
TSX Engine Harness $150
TSX K24a2 Header w Shield $50
Del Sol Tail Light Pig Tails $20
Del Sol Passenger Pillar Trim $15
B Series GSR Shift Linkage with Dual Bend Shifter SOLD
Del Sol D Series Shift Stabilizer Bar $25
Dual Bend Short Shifter (from the looks and weight it seems like a skunk 2 which is identical to the skunk 2 in my car but neither have markings) $50
92-95 Civic Coupe Headliner $50
JDM ITR Header SOLD
CRX Euro Tails $25
CRX Si Wheel $25
P06 ECU SOLD
GSR P72 Head SOLD
GSR Stock Cams SOLD
GSR Shortblock SOLD
