PART OUT: 91 Prelude, H22, LSD trans, Hondata, ROSKO, RyWire
Old Jan 31, 2010 | 07:27 AM
team123luder's Avatar
Default PART OUT: 91 Prelude, H22, LSD trans, Hondata, ROSKO, RyWire
You guys have mostly seen my car/stuff and know it's in prime condition. Most of my prices are OBO but seriously, half the crap I have is hard to come by now and will cost you most then you can imagine, especially my JDM rear seats.
Engine/trans
1. H22A long block with no manifold (stock mani included but not installed)
1000.00 This engine was bought out of a 4GP with less then 40000km. I pulled the head, changed the head gasket, waterpump, oil pump, timing belt, H23 tensioner, new valve cover seals, Iradium spark plugs (40 bucks they're brand new, less then 100miles on them) It makes gobs of compression and runs perfect. oil changes every 2200miles with synthetics
2. JDM H22A LSD transmission-1100 dollars will include my LSD custom heavy duty clutch, pressure plate and ACT street lite flywheel. Transmission has absolutely no grinds and is very smooth. Nothing but Honda MTF used
3. Custom Highend header (similar to camp1320) 350 NO DINGS!
4. Rosko Euro R manifold-500 Yeah I know thats what they cost straight from him but guess what? NO SHIPPING! And no wait, Rosko himself is waiting on Euro R manifolds. This is one if not the last 70mm version he made and is flawless. I'll include the Hondata heat shield.
5. Skunk 2 70mm TB-150, needs to be greased up a bit again. I used to remove it about every 4 months (sitting in my parking lot) cause the grease I used would just dry up to quick and cause it to slightly stick. Once greased it's fine. I wet sanded the inside of the TB to cure this and it's already properly calibrated. Will include TPS already adjusted.
6. 3GP OBD0/H22A RyWire harness w/ Jumper-350-The wiring is flawless. Got it at this price from Ryan when we had the GB for it. It has all the sensor wiring and if you want to BAR your 3GP this harness will comply.
7. Hondata S200-400.... This ECU is already tuned for my entire setup and made 211whp. It has all the wiring for the 2step and diagnosis for the S200 which are very rare to come by. And has a P28 already. This is discontinued and your only options are S100 or S300 which is about 600 bucks for just the unit and no ECU.
8. Custom 3GP/H22 axles-80 bucks... I made these myself and they work and are fine.
9. Forbidden SS-100
10. shifter cables and customized shifter box for 3GP-60
engine misc.
11. civic half rad with electric fan-Took this through blazing hot weather, ran fine. 100
12. silicone hoses 3gp (top was slightly cut) 20
13. Fuel gauge, liquid filled-20
B&M Adjustable FPR- 40 (already setup)
exterior
14. VIS og CF hood-300, NO CRACKS! the hood is faded but I was quoted 50 bucks to reclear it. So for 350-400 dollars you can have a clean looking 630 dollar hood WITH HOOD HINGE! New VIS 3GP hoods don't have it and require hood pins. I've done over 155mph with out hood pins.
15. USDM fender red-100 great condition
16. USDM fenders red- 60, they have the sidemarker cut outs and are meh.
17. authentic BA4 sidemarkers-55 have bulbs and harness, flawless condition.
18. 3GP bra-100 bucks, check out mugen machinas car... it's bitchen. Great condition and authentic. HARD TO COME BY
19. INX tail center-100 NO CRACK in great condition
20. folding mirrors-150, AS IS, they come with relay, harness plugs, switch. Switch is slightly damaged but everything works. "passenger" mirror needs to be greesed
Interior
21. Black interior-100 bucks NO SEATS
22. JDM rear seats-180 just the headrests 150 since the rest is pretty close to USDM seats... VERY RARE!
23. ARM REST IN MINT CONDITION-120
22. Rear Si deck-20 this eliminates that ugly 3rd brake light which you don't need
23. black center console-40 comes with radio surround and cassette pocket!
24. Ver2 Si front seats-60 passenger has come apart at the seem, can be repaired and both seats have little wear on them but are otherwise in good condition. The driver seat is bitchen adjustable! HAS MEMORY
25. SI FOGS COMPLETE!-150, these are super hard to come by now especially with good brackets like mine. Will include switch and relay plus front harness!
26. extra fogs-80, just fogs, screws have some rust but lens are clean.
extras.
27. Neuspeed race springs-120 dollars, drove these for less then 5k miles
28. tokico blues-120 great condition, some scuffs
29. Custom Eibach coilover sleeves-120, these were made for me and aren't marked but they are meant to hold the h22 up front. FRONTS ONLY
30. EM racing C pillar bar-150, lol go ahead and try and get one. I did most if not all the R&D for this bar with EM racing. this is the group buy price. I sold 3 sets on ebay for over 189 plus shipping.
31. goodrich brake lines-100 BRAND NEW!!!!!!
32. REAL DEAL VOLK TE37's- old school 5 spoke TRACK R'S! You can find the white ones pretty easily and in mint condition. These are track R versions, thus they're red. They are sun damaged and slightly scuffed, bought like this from a friend who used to track his K20CRX. They have 70% thread left on the current tires. 205/50/16, Buy these, get them redone and have one of a kind wheels! 1200 (Sale is pending currently)
AZ RACE MOUNTS 360- good condition...
NRG quick release/short hub/deep corn steering wheel. I bought this last year, it's less then 6 months old and obviously works on the 3GP 180 bucks
You can buy the entire 3GP change over for 4200 dollars. I paid 3500 dollars for my entire change over with out axles, S200, dyno tune, full bolt ons and lots of other items. I'm losing well over 3k on this
If you want to do an H22 swap on your 3GP this is the time to do so, I'll even through in the 2.5" crush bent exhaust for you.
Most prices are flexible but you guys know my **** is good and DON'T LOW BALL ME!
Also the entire car is up for parts, spindles, control arms, tail lights, head lights, bumpers, eagle rear diffuser, trunk, rest of interior, doors, etc etc etc.
Just let me know and I'll give you a price
PLEASE BUMP IF VIEWED TRYING TO BUY A HOUSE AND THIS WILL HELP!
Old Jan 31, 2010 | 02:09 PM
civichb20's Avatar
PM Garage
Default Re: PART OUT: 91 Prelude, H22, LSD trans, Hondata, ROSKO, RyWire
bump gl with the house
Old Jan 31, 2010 | 05:34 PM
Thanks man, if it wasn't a home then I would never part with my "suzie", though life rocks just a tad more then my hobby.
Old Feb 1, 2010 | 02:34 PM
JDM_CD7's Avatar
Shoot me over some pics of your SS shifter.
Im in pasadena so I can pick up soon.
Old Feb 2, 2010 | 06:42 AM
The entire car sold just yesterday night!!! Sorry fellas, money talks!
thanks for viewing.
Old Feb 3, 2010 | 04:19 PM
hdragster's Avatar
I'll bump for viewing :]
team123luder
Feb 3, 2010 04:58 PM
typr2nv94
Jan 5, 2010 10:21 AM
93accordEX
Jul 30, 2005 08:34 AM
FoundryWorks1
May 11, 2005 05:04 PM
H22A EG6
Jun 2, 2004 08:28 PM
