Can someone recommend some injectors for us?? D16Y8 and B18B
Old Jan 31, 2010 | 01:32 AM
Arthas's Avatar
Default Can someone recommend some injectors for us?? D16Y8 and B18B
Sup all.
Finally decided to go boost and sold off trash for this.
My brother has a 96 Integra and I have a 99 DX with a Y8. Were both going eBay turbo kits (made up our mind) with stock internals. I believe I already found our tuner but were still shopping around.
Im trying to shoot for 170whp maybe less depending on the set up but I want some good mid end power. Hes shooting for around 220 since we rode in some guy that was pushing that on a stock B18B and that thing was fast. :shock:
Im hoping the head gasket or something blows and my motor doesn't throw a rod.
So with that said in mind, what CC injectors do you guys recommend? I dont want to go too high if it isn't necessary. Ive heard people talk about H22 injectors and I have a spare resistor box left over since my brother got RC injectors for his ZC+T set up.
Thanks!
PS: I MUST be able to beat a Type-S.
Old Jan 31, 2010 | 06:13 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Can someone recommend some injectors for us?? D16Y8 and B18B
budget and ems?
just throwing a dart, 450's and a resistor box.
BUT if you have the money to get saturated injectors, 550cc's you wont need a resistor box.
Old Jan 31, 2010 | 11:38 AM
Arthas's Avatar
Budget is low, as in super low.
So 450s for the both of us?? I just sold my xbox so I can have cash to pick em up.
Old Jan 31, 2010 | 11:52 AM
boostedEF91's Avatar
A set of dsm 450cc will be cheap and work just fine. you will even have room to play around with. but as for using ebay turbo kits. get a cast manifold do to all the SS mani's crack from ebay. just a heads up i'll give you. as for a resistor box. you also can just go to radio shack and get 10ohm resistors. and wire them between the injector wires.
Old Jan 31, 2010 | 01:28 PM
Schister66's Avatar
Man U FTW
If cheap is your main criteria, then DSM 450s are hard to beat. On gasoline, those should allow you to break into the upper 200's at the ground which is enough for your goals. Buying 2 sets of 450s and 2 resistor boxes shouldn't run you any more than maybe $150.
Old Feb 2, 2010 | 12:10 PM
Arthas's Avatar
Okay cool beans I appreciate your help pps.
My brosef bought his previous injectors from eGay. Any other online shops you guys recommend so I can order them?
Old Feb 2, 2010 | 12:31 PM
Schister66's Avatar
Man U FTW
I would check www.hondamarketplace.com in the Classifieds: Forced Induction section. There is a treasure trove of parts there...
Old Feb 2, 2010 | 02:08 PM
mtber's Avatar
Precision 440cc injectors would be the cheapest "brand new" solution.
Otherwise, look for some clean dsm injectors & a resistor box.
Old Feb 2, 2010 | 10:51 PM
Arthas's Avatar
Ill check out the market place.
I found some 450CC DSM injectors on eGay for about ~$75 shipped.
Well both need the resistor box right?
and would any resistor box work? I found some 450CC's with resister box but the box looks different than others.
http://cgi.ebay.com/ebaymotors/Honda...d#ht_500wt_959
Found that set up, didnt look too bad. But its 390CC and you guys recommended 450's for the both of us.
Old Feb 3, 2010 | 08:36 PM
Arthas's Avatar
Okay picked up 4 450cc injectors and picking up the other 4 tomorrow.
Can a car be tuned with an OEM clutch or does it need a stage x clutch? My brother has a Stage 2 and I have the OEM with about 5000 miles on it.
If I do need the clutch ill just wait out on the install, but im just curious.
Old Feb 3, 2010 | 08:53 PM
TehGhett0P1mp's Avatar
OEM clutch wont hold the power for long, but doesnt mean you cant use it till it starts slipping.
Old Feb 4, 2010 | 04:45 AM
Schister66's Avatar
Man U FTW
You should switch the clutch before the dyno...it would suck to get there, get strapped on and toast the clutch during one of the first pulls. It would be more expensive to cheap out in this instance. You dont need to get anything too fancy, but i would get something better than an OEM clutch. I would prefer something cerametallic as the organic (lower torque rated) clutches can glaze easier
Old Feb 4, 2010 | 05:38 PM
Arthas's Avatar
Can the car still be tuned on OEM clutch?? The clutch has maybe 1000-1500 on it and never raced on it. I know for a fact it wont hold the power, but it can be tuned right?
Any recommendations on what clutch to get? I know clutches are rated at torque but im not sure what torque im going to get. Im hoping for 160ish whp for my Y8, and my brother is pushing for 200whp on his B18B.
Old Feb 5, 2010 | 04:49 AM
kyden's Avatar
it can be tuned up until it starts slipping. most tuners will just end it as soon as slipping occurs, so its up to you.
b16bri
Sep 5, 2010 02:53 PM
TXGrunt
Dec 4, 2006 05:37 PM
Project_EK
11
Jul 24, 2006 02:41 PM
c1v1c_R
May 1, 2004 07:26 PM
TurBoTeG
Jul 12, 2002 05:55 PM
