rebuilding gsr
Old Jan 30, 2010 | 11:31 PM
classdork987654's Avatar
Default rebuilding gsr
i am rebuilding my gsr with either ls crank and rods or stock gsr crank and rods with p30 pistons. but my question is can i run my motor with the stock cams and adjustable cam gears and still make power or will i lose power over stock? reason for not doing cams is lack of money and my motor took a dump on me ha ha. motor will be dd and c a few autox events. have been searching google and what not but have not found clear answers. or would it be worth it to wait it out and get cams, what cams are people running with these setups?
Old Jan 31, 2010 | 08:43 AM
95 integra's Avatar
Default Re: rebuilding gsr
It should make slightly more pwr.
Old Jan 31, 2010 | 09:13 AM
ruffrhyder's Avatar
Either build you choose, it will make a bit more power if built right, even with stock cams. In one case, you'll be gaining displacement, good for more torque, and a few hp throughout the entire power band. In the other case, you'll be gaining more CR, should also gain a few more hp.
myEKsedan
Feb 22, 2013 02:08 PM
happyabortion
Nov 27, 2008 09:13 PM
sickofitall1113
Apr 3, 2007 09:19 PM
oilguzzler
Nov 29, 2005 04:28 PM
AK94GSR
Aug 1, 2002 03:39 PM
