Need some help with an Idle problem
Old Jan 30, 2010 | 09:00 PM
llslick's Avatar
Default Need some help with an Idle problem
Whats up everyone I'm having an Idle problem with my sister's 91 civic std. with and d16a6 si swap. I put the swap together from parts I had lying around and has been running good for about 2 years. It recently started acting up the car would run then die on the initial start up then when turned on the 2nd time would run fine but with idle around 1500. I tested IACV, it was at 15 ohms specs are 8-15 replaced it with another used one and now I have a loping issue from 1000-1500rpm. I tested the other IACV it was at 11ohms. Do I just need to bite the bullet and buy a new one or is there another problem that im over looking. Please help me out
Old Jan 30, 2010 | 11:55 PM
BiG ChOr!Zo's Avatar
Default Re: Need some help with an Idle problem
http://ef-honda.com/ben/Badidle.php
slikz
Mar 28, 2010 06:22 PM
d4rks1d3
Jun 3, 2004 09:21 AM
