F/S 95 Gsr Integra Jacksonville
Make:Acura
Model:Integra Gsr
Year:1995
Mileage: Body unknown Motor 3,500
Options
ower Windows,Sunroof,A/C,Heat,cd player,power steering,full leather
Engine: Built Ls/vtec 1.8 bored .20 over, eagle rods,super tech 12:1 pistons, new acl bearing kit, new type r water and oil pump, all new gaskets and seals, b16 ctr head and cams and type r intake manifold, blaster external coil, greddy header,fluidyne radiator,polished valve cover,spoon thermostat,moroso oil catch can vented from back of the block. New optima red top battery relocated to trunk. Led fuse block under hood,str fuel rail, etc.etc.etc New axles, Rc 270 injectors,toda cam gears,fidanza flywheel, compettion stage 2 clutch,hasport mounts all three
VIN#:upon request
Wheels/suspension: Gsr fat fives, tires are at 80% tread. Lowered on a set of H&r springs, stock struts.
Bad: Car was stolen and had the previous motor stolen and seats and steering colum. I put everything back in and together. Car runs like a champ. Its running on a base map, and needs a tune. ALso could use a paint job.
$ 4500 obo
Model:Integra Gsr
Year:1995
Options
ower Windows,Sunroof,A/C,Heat,cd player,power steering,full leatherEngine: Built Ls/vtec 1.8 bored .20 over, eagle rods,super tech 12:1 pistons, new acl bearing kit, new type r water and oil pump, all new gaskets and seals, b16 ctr head and cams and type r intake manifold, blaster external coil, greddy header,fluidyne radiator,polished valve cover,spoon thermostat,moroso oil catch can vented from back of the block. New optima red top battery relocated to trunk. Led fuse block under hood,str fuel rail, etc.etc.etc New axles, Rc 270 injectors,toda cam gears,fidanza flywheel, compettion stage 2 clutch,hasport mounts all three
VIN#:upon request
$ 4500 obo
anothersickhatch
Oct 19, 2006 05:18 PM
