90 civic si wont start!
Old Jan 30, 2010 | 05:14 PM
redEFsocal's Avatar
Default 90 civic si wont start!
Hey, i am trying to get my HB on the road, cuz my VW is a pile. I needed to buy a starter and alternator because i was jumping my starter for awhile an it made my alt. go bad, so i replaced them both an when i try to start the car with the key nothing happens. I get all the lights fuel pump turns on, but will not crank. I can jump start the starter and the car will run. what can I do to fix this problem? the ground wire is connected an the connector is connected.
Old Jan 30, 2010 | 07:53 PM
AndThenYouSay's Avatar
Default Re: 90 civic si wont start!
buy a manual lol. it takes some trouble shooting. start here.
1) check ALL fuses.
2) connectors btw starter and the fuse box.
3) starter relay
4) ignition (in steering column)
5) you cooked some wiring
Hope that helps
Old Jan 30, 2010 | 09:03 PM
llslick's Avatar
Check for loose connections battery,starter.
Old Jan 31, 2010 | 02:19 PM
redEFsocal's Avatar
Thanks for your help, ill try that out hopefully i can figure it out.
Old Jan 31, 2010 | 06:12 PM
alscrx's Avatar
Check your ignition switch, mine was bad in the crank position. I got all the lights also but no crank.
New switch is like 50 bucks from honda.
nestea8869
10
Mar 26, 2022 10:12 AM
mrboompow
Apr 2, 2016 02:56 PM
vplukas101
Jan 25, 2013 04:09 AM
ftrms
15
Dec 22, 2010 04:05 PM
stl eh2
Dec 3, 2009 10:07 AM
