got brake hoses replaced and now no pressure after bleeding
Old Jan 30, 2010 | 02:04 PM
cityofcaterpillars's Avatar
Default got brake hoses replaced and now no pressure after bleeding
ok so long story short I replaced my brake hoses and forgot to replace the crush washers. Im going to replace them in the morning. Will not having them on cause the brakes not to build pressure while bleeding them? It builds when the car is turned off but not on.
Any help would be great
Old Jan 31, 2010 | 02:43 PM
hondamark35's Avatar
Default Re: got brake hoses replaced and now no pressure after bleeding
the crush washers act as the banjo fitting seal. two washers per fitting need to be replaced with new ones (be sure they're super clean. a little bit of dirt or grit can keep it from sealing properly).
that should allow you to build pressure.
Old Jan 31, 2010 | 03:06 PM
Yeah I replaced them today and everything worked right. The brakes still don't grab real good though but I think it's because the rotors are shot.
denniscoles
Mar 13, 2008 04:16 AM
integobsession
Mar 11, 2008 10:03 AM
veggiemaster
Jan 26, 2006 08:28 PM
B18EG6
Jan 29, 2003 09:55 PM
