gears are hard to get in high rpm
Old Jan 30, 2010 | 02:04 PM
algerian74's Avatar
New User
Icon6 gears are hard to get in high rpm
I have a problem with my 1995 gsr, i changed my trans fluid and still the same so i changed the shift linkage still the same, mines grinds when i try to put it in fifth gear and its hard to put it in gear on high rpm also my shifter moves left to right even when its in gear just as if its in nuetral, any idea what the problem could be? is it a cluch or transmission problem? hopefully someone could help us out here thanks guys God Bless
Old Jan 30, 2010 | 03:42 PM
mouab18c1's Avatar
Default Re: gears are hard to get in high rpm
if its just one of your gears grinding then its usually your syncros going out in that particular gear
Old Jan 30, 2010 | 05:56 PM
my_gsr_teg's Avatar
hmm seems like you have a tranny starting to go bad...what kind of transmission oil did you use?
Old Jan 30, 2010 | 08:01 PM
DC2..Type..R's Avatar
It could possible be the start of your master clutch cylinder going out....if it is you should be able to find signs of it leaking....mine leaked all over the inside of my cab and didnt even know it till I noticed it was low on fluid. it seems quite abnormal to have that much play left to right tho...?
infamouskillas
May 17, 2008 09:56 PM
humboldt_skim
10
May 16, 2008 10:56 AM
kornerk12
Jun 11, 2006 07:00 PM
AzntstyleZ
Jun 27, 2005 08:21 AM
ChillOutWayne
Jul 31, 2004 10:35 PM
