How to take off my valve cover?
Old Jan 30, 2010 | 10:00 AM
SisterFister's Avatar
Default How to take off my valve cover?
hey i need to take my cover off cause the threading on my oil cap broke off and is now stuck, and if i try to take it off by hand it will just fall off into the head...which is bad i bet...well anyway
what tools are needed and whats the process of doing it? Thanks alot!!
Old Jan 30, 2010 | 10:03 AM
Radim's Avatar
Default Re: How to take off my valve cover?
10MM Socket, remove spark plug wires, unbolt the bolts.. if you havent taken it off in a while it might take a bit of strength to take it off.
Old Jan 30, 2010 | 10:32 AM
got it thanks Radim!
Old Jan 30, 2010 | 12:48 PM
robofunc's Avatar
You should also use some RTV silicone sealant and a replacement valve cover gasket set. Otherwise you'll probably get oil leaks later.
Old Jan 30, 2010 | 01:25 PM
crx_si-r's Avatar
You shouldn't need silicone if your replacing the gasket. Also you don't need to remove the valve cover to remove the broken piece of the oil cap. Use a towel, gloves or bare hand if you like. Apply preassure to the remaining piece of the oil cap and twist n turn your hand an it should spin out of the valve cover. It wong fall in unless you tighten it and spin it into the head.
Old Jan 31, 2010 | 08:16 PM
CRizzl JDM <3's Avatar
failure
curtie94
Apr 2, 2011 03:46 PM
gregINaTEG
Jun 16, 2009 12:37 PM
garykf16
Apr 13, 2009 04:09 PM
knucklehead11
Jul 31, 2004 05:13 AM
optikal_blitz
Apr 21, 2003 01:44 PM
